![]() | Home > Maintenance & Mods (L322) > Nutty prices - swollen nuts |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Well, following on from my quest to eradicate squealing from the front wheels:
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
i doubt if that would cause a squeal ryan, single nuts are available from ebay/powerfuluk
Thank you Stan... I've just ordered a new pair of nuts |
first you had a screw loose and now you're nuts.... |
Using this search description just ordered a set of 5 for £15.70 including free delivery by Wednesday:
| Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315
Should you find said squeak please advise as yours sounds identical to mine even to the location and it's the worst sort, intermittent.
Apologies Paul, I actually resurrected this thread on the subject of swollen nuts. We no longer have the RR that the squeak related to and don't want to dishearten but the overwhelming feeling from professionals at the time was that the squeak was connected to the front brake pads I had fitted which were not LR but Brembo pads (in fairness the squeak wasn't there with the previous LR pads).
Ah ok thanks anyway.
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473
http://www.advancedfactors.co.uk/rrd500510...5929-p.asp |
When you say new genuine Brembo pads... Purchased from where sir? |
Hi Craig, supplied and fitted by my good friend Chris Mullens tyres here in Gloucester, £115 all in from memory. Many thanks
Pv... Craig has previously queried references to 'Brembo' pads... A la Brembo don't actually make pads |
I was offered std or genuine Brembo and have 100% trust that that's what I received.
It seems to be a source of debate. Can you or can you not get 'Brembo' pads. |
| All times are GMT |
