Home > Technical (L322) > Front headlights
rr driver
United Kingdom 2011 Range Rover Autobiography 5.0 V8 Santorini Black
Front headlights
Apologies if this has already been discussed i couldn't find anything.
My passengers side front main headlight seems to have turned an amber colour. I have a my2010, 2009 5.0SC.
Is this my bulb on its way out or something else. If the bulb, is it a simple, take it to the dealer/halfords fix.
thanks 2011 5.0SC Santorini Black
2009 5.0SC Santorti Black - Been stolen.
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #360617 6th Dec 2015 1:36am
Yes & yes... Quite simple BUT!!! £150 per bulb at stealers!!! £40+ per pair on the bay of fleas Whistle
Post #360643 6th Dec 2015 10:28am
rr driver
Thank you Craig. Will search the bay. 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #360668 6th Dec 2015 12:27pm
rr driver
Ok, silly question, where can I find out which bulb type I have. I can only seem to establish that the lights are xenon bulb type? 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #360673 6th Dec 2015 1:01pm
pretty sure its a D3S type...someone with more knowledge hopefully will confirm this.. ... - .- -.
Post #360682 6th Dec 2015 2:46pm
Weegie
As Stan says, looks like D3S.
Bulb guide here: http://www.lightbulbs4cars.com/land%20rover%20bulb%20guide John
GAP iiD BT-Sold
Post #360688 6th Dec 2015 3:16pm
Zirconblue
i think even Halfords do them these days.
Post #360698 6th Dec 2015 4:49pm
rr driver
Thank you. 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #360797 7th Dec 2015 12:06am
just to point out that there are different colour temperature xenons available..
the standard temperature is 4300k which gives a very slight yellowy tint but you can get 6000k which is a more whiter light with a slightly blue tint..its claimed that the higher temperature you go , the more brightness you loose but i find that because the 6000k is whiter , the brightness 'appears' the same ..
obviously if you change one bulb to 6000k then its preferable to change the other ..... ... - .- -.
Post #360834 7th Dec 2015 9:45am
If one bulb is on its way out, i guess the other will follow suit very soon after! Always best to have a matching pair fitted Thumbs Up
Post #360836 7th Dec 2015 9:51am
Zirconblue
and they change colour with age, so even if it doesn't fail it's still best to pair them up.
Post #360883 7th Dec 2015 4:33pm
rr driver
Ordered 2 today, decided to stick with the 4300K. Current ones fitted were Philips Ecostart so ordered two for 80 from amazon.
So many options was tempted to go for the brighter ones. 2011 5.0SC Santorini Black
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #360992 7th Dec 2015 11:54pm
fisha
They definitely appear whiter / blue-er, but in the wet, I find you notice they just don't quite show the road as well as the lower 4300k temp bulbs. V8 or else ...
Post #361011 8th Dec 2015 7:48am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
They do!!
Found that out a couple of months back! Offside one went, I had a replacement in the garage from when a Pheasant took out the offside indicator unit not long after we bought the car so we had to have a new headlamp as the lugs to locate the indicator unit were totalled!
Replaced the offside bulb then a week later the nearside one went pop! Think it was around £60 from Halfords.
Post #361068 8th Dec 2015 1:26pm
