![]() | Home > In Car Electronics (L322) > Rear dash camera fitment |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8121 ![]() ![]() ![]() |
You have 2 choices, either fool the car into thinking it's reversing by tapping into the wiring - which is what I assume the switch that Welshdragon installed is for - or you can disable the safety feature that prevents you watching TV whilst on the move.
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Thanks for the tip, will do more digging, |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
The switch I fitted is the 'fooling' way of wiring it up, I did not want the reversing light to switch it on as wanted forward viewing for the trailer, which works brillianty.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
I had/have a little box that I used on my E60 when I had it. I wired it to the reversing light but also to the can-bus so that I could press the knob in the centre console and it would come on without selecting reverse.
Hello WD yes all the same, I ordered from the links you posted, I get a good picture on the head unit if it is set to Pal and the connection from the cam is in the video in jack with the earth from pin 17 not connected, when I wire it up as per instructions it messes the computer around and it does all silly things, like activating the GPS on its own. Can you tell me a bit more about that switch on the centre consol |
My switch is just a normal rocker type with 2 pins, simple on off which goes through to pin 17 on blue connector. The switch would of been the reversing light to activate camera, don't know why your gps is going on?! A bit confused about that sorry.
Good morning to you, sorry if I am a bit vague |
Hmm got me on this one, I have no idea why the courtesy lights come on and you naviation too, mine dont, also to answer your first question (I've reread my hole thread again) yes the music does play in the back ground.
Its been a while but I do look in now and then to see whats new here!
