![]() | Home > Technical (L322) > brake lights and hdc fault |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Sounds to me like your Hawkeye is playing up... With that array of lights you would think it would have more faults logged.... Pete
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419
Sounds like you have a short to positive that's turning on the brake lights, so what the Hawkeye is reporting is correct.
| dogswick Member Since: 14 Jan 2012 Location: ever sunny yorkshire Posts: 20
haylands, thought that at first or maybe the red adapter but everything else i.e. service functions and other test work fine so pretty sure the hawkeye is fine.
They do come on with HDC, mine came on on their own with the ignition off after I drowned the car in a river... could be water in your electrics somewhere, check the carpets for dampness... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
re brake light on, check the body control ECU in the passenger footwell, it might have got wet from blocked sunroof drain pipes..
I like a challenge and this could be a complex one!
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
^^^ Stunning |
Weejock you are a deity. |
No problem, glad you got it sorted! |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459
@Weejock - great bit of detective work there |
| DDJJKK Member Since: 24 Nov 2014 Location: Perth Posts: 1
Great posts helped me diagnose the exact same problem with my l322 td6 abs ECU faulty
| All times are GMT |
