Home > Technical (L322) > Towbar electrics 7 pin to 13 pin
Page 1 of 4 1234>
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Failed in searching so....
Mine (2008 tdv8) has a 7 pin and wish to upgrade to the 13 pin and so ask if anybody can point me in the right direction ideally to a plug and play position.
As long as the sensors cease I'm not to concerned with all the bits and bobs a dealer codes in as I'm only tugging a small bike trailer.
Thanks in advance. Many thanks
Paul
Post #361581 10th Dec 2015 10:05pm
is this any help,
http://www.fullfatrr.com/forum/topic25688....pin+13+pin ... - .- -.
Post #361582 10th Dec 2015 10:09pm
Pvw10
Some good info there thanks but doesn't answer it all sadly, I searched in just the 322 forums, will try wider searches next time. Many thanks
Paul
Post #361586 10th Dec 2015 10:34pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I changed mine from 7 pin to 13 following a fire on the socket. It's quite easy, plug and play loom, p obably the most difficult part was threading the new loom through the boot floor.
http://www.fullfatrr.com/forum/topic28223.html
If you have any specific questions just let me know Smile
Post #361593 10th Dec 2015 10:53pm
Pvw10
Cheers for that
On the net I see looms, plug on one end full length of the car to the rear cubbys for about £85, is it one of those, but answering my own question I guess it has to be.
So in simple terms it's a swapper ? Many thanks
Paul
Post #361596 10th Dec 2015 11:08pm
Pvw10
Fleabay item eBay Item No. 131294496090 is the item yes ?
What happened with the floor you kindly flag up ? Many thanks
Paul
Post #361600 10th Dec 2015 11:23pm
Fish
That looks like the harness. I can't find the link to the one I bought but will keep looking.
The kit should include the towing control module and the relay which go in the hand cubby hole in the boot. They are plug and play but the plug on the control module is a bit tricky as you have to slide part of it to release it rather than just unclip it. Both parts just unbolt from their mountings.
The wiring runs to the boot floor close to the tailgate across to the left hand side where it exits through a hole with a large grommet. The new kit will have a new grommet on the wire already. I had to take the trims off the boot and lower tailgate to get to the old harness which is tightly clipped in place. Once you expose this just run the new one the same way.
The grommet was quite difficult to fit but at least you know it's a good seal once in.
You may find the screws on the old tow socket have rusted in and it may be easier to undo the mounting plate and cut the wires so you work hard n them off the car. My plate was also rusty so I took the opportunity to clean it up and spray it Matt black before refitting.
There is nothing too difficult just some bits are a bit fiddly or frustrating. Some random pics below Confused
The white box is the control module which bolts to the side in the cubby hole
Hope this helps.
Post #361637 11th Dec 2015 7:44am
Pvw10
As our friends across the pond would rightly say, " totally awesome reply" I can't thank you enough, pictures so much easier than words.
I see your brew stand is similar to mine he he
I recently changed my electric plug holder to a posh stainless steel jobby, also the bolts in the plug the same so that pain I've already been though.
Fully understand your words so will get a good quality lead on order.
Small world when we lived in Middleton my Dad worked in Bolton before moving South.
Any ways thanks again, much appreciated. Many thanks
Paul
Post #361647 11th Dec 2015 9:59am
miggit
This is the kit that I used on mine, it's of a similar price, I can say that It's plug and play, and easy to fit Thumbs Up
http://www.pfjones.co.uk/range-rover-13-pi...13-en.html
And has the advantage of being Westfalia in origin who are the Land Rover Suppliers (i.e. genuine, but no L/R stickers and no L/R silly prices Very Happy ). There are a few of us on here who have used PF Jones, and I have yet to hear a bad word said about them, although I bet L/R have a few Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #361673 11th Dec 2015 11:38am
Pvw10
That's the one for me then, quality counts big style, many thanks. Many thanks
Paul
Post #361685 11th Dec 2015 12:19pm
fisha
I was a cheap skate and bought a new 13pin socket, and undid all the existing socket wires of the 2x 7 pin sockets and re-wired them into a 13pin socket. Seems to work so far!
Sub £10. Laughing V8 or else ...
Post #361701 11th Dec 2015 2:12pm
Pvw10
Good plan
I only have one 7 pin so hands are tied. Many thanks
Paul
Post #361702 11th Dec 2015 2:14pm
miggit
Whistle You could always flog your genuine L/R wiring loom and ECU on fleabay.... who knows, you might make a profit Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361704 11th Dec 2015 2:37pm
Pvw10
Sounds like a good plan, unsure if mine is pukka.
Fitted this hitch on, woe betide anybody that rear ends me, it's good for 5t just need a suitable cover rather than the naff thing seen on there now.
Found as soon as parking sensors sound solid I have to stop or..........bang he he Many thanks
Paul
Post #361707 11th Dec 2015 2:43pm
miggit
That's a Witter tow bar, which is after market, so there is a chance that you just have a bypass relay fitted and it's been programmed to the car, not sure what will happen if you plug genuine electrics in to that, hopefully it will recognise that you've come to your seances and just work without any fuss. Or if your really lucky you've got a cheap towbar with genuine electrics and all will be well Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361714 11th Dec 2015 3:10pm
Page 1 of 4 1234>
