Home > Technical (L322) > CV Gaitor
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
CV Gaitor
Morning.
A few months ago I have front offside lower arms and CV Joint replaced. I had to return to the garage a couple of times afterward as was getting creaking from the fixed area, turns out it was a Faulty lower arm and was replaced. A couple of weeks later I had to return as there was grease spattered over the wheel and wheel arch.
Apparently a faulty gaitor (who would have thought genuine parts would be faulty so much!) Again, fixed and seems fine since. Last week had front discs and pads replaced at a different garage and he said the clip has come off the CV joint and the gaitor has moved again.
Is this common? Is there a special Jubilee clip or zip tie I should be using or ordering? Keen to avoid another 1K bill!
Cheers
Post #361656 11th Dec 2015 10:31am
Yes there is a special clip which needs a special pair of pliers to attach it sir... Thumbs Up
Also check you have not had a rear gated sent to you by mistake sir Whistle They will fit but pull off all the time as they are different from the front ones! A common mistake made by parts people I’m afraid! (a very expensive one too!!!)
Post #361660 11th Dec 2015 10:38am
Mcnallykev
Thanks Craig,
How do I check?
Post #361662 11th Dec 2015 10:39am
Look at both sides OS - NS and see if they are identical? And compare the replaced one to a rear one on your car sir Thumbs Up
Post #361664 11th Dec 2015 10:42am
Mcnallykev
Who would have thought it was that obvious!! Rolling with laughter Rolling with laughter Rolling with laughter
Post #361665 11th Dec 2015 10:43am
Mcnallykev
Apparently it was a full kit from Land Rover. I must just be very very unlucky.
Post #361670 11th Dec 2015 11:17am
Better fitting the stretchy rubber CV boots, they are more plyable and last much longer
Post #361682 11th Dec 2015 12:09pm
I don't wish to cast dispersions on your garage but are you sure they did the work the first time, a faulty arm sounds a bit weird, it's an arm with a bush in it and maybe a balljoint at the other end, depending on which one it is...
Did they do the old trick of cleaning the gaiter and super-gluing it back together, this then failed throwing grease everywhere... and when they did replace it they used a cheap pattern part...???
I hope not and you're just unlucky this time but it does sound a bit odd.... Pete
Post #361708 11th Dec 2015 2:52pm
Mcnallykev
It seems odd. I have spoken to the garage and they say that the boot doesn't have a clip to attache to the shaft side. As I am typing this it sees to make sense as obviously the shaft needs to rotate in order to drive the wheel.
But if thats the case how does the grease stay in? Any help appreciated.
Post #362181 14th Dec 2015 2:44pm
The shaft and the CV joint and the boot all rotate at the same time. I think you need to find another garage if they think it shouldn't have a clip
Post #362183 14th Dec 2015 2:47pm
Mcnallykev
Sounds about right!! Know any good LR garages near by anyone?
Post #362188 14th Dec 2015 3:02pm
There's a good non LR garage in Carluke that I would recommend
Speak to Alan Mills, if he can't help you he'll tell you straight
Click
Post #362206 14th Dec 2015 5:30pm
Mcnallykev
Excellent, will do!
Thanks
Post #362211 14th Dec 2015 5:48pm
