Home > Technical (L322) > Battery drain......sad face
Page 3 of 5 <12345>
Thumbs Up Thumbs Up Pete
Post #360795 7th Dec 2015 12:48am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Good news - don't forget to post back if the problem is solved - good info for others Very Happy Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #360867 7th Dec 2015 2:49pm
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
***another update***
Monday morning (this morning) car started no problem, bare in mind it was last started Sunday at 2pm for a short drive home so almost 18 hrs had past.
Had the new battery fited this morning and all is well.
I have now added the fuse back into the car but actually removed the sat nav unit completely as that fuse also runs the on board screen in the dash.
Now it's just a matter of time and just need to wait. If the battery dies then I haven't found the problem if it stays alive then it could have been a dud sat nav or dud battery.
Watch this space......
Post #360889 7th Dec 2015 6:03pm
rangeseb
***update***
Good Morning.
So its been 5 days since the new battery went in and the Sat Nav unit has been removed and so far so good!
this week the FF has had early morning starts at about 6am and the normal stop/start trips to work and home and shes running good.
All i can hope is i have solved the problem, either the battery was weak, damaged or not powerfully enough or maybe the sat nav was the problem.
The battery i had installed was a Lucas battery, Capacity 110Ah and CCA 920a
Post #361684 11th Dec 2015 12:15pm
miggit
That's the "Heavy Duty" spec for the ffrr Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #361687 11th Dec 2015 12:27pm
rangeseb
Well the guy at Bennington 4 by 4 said that's the battery he recommends due to the size of the car.
After looking at replacing the Sat Nav, i have decided to leave the car version and purchase a Tom Tom.
the price of a replacement unit and a C.D to upgrade the maps is more than a Tom Tom so doesn't make sense. Specialty when most of the Tom Tom's these days are flat and small so can by placed by the speedo or just on the window.
Post #361697 11th Dec 2015 1:55pm
miggit
You forgot a Tomtom's best party trick....... you can plug it in to your computer and UPGRADE the maps Shocked
I have also discovered that if your Tomtom goes fubar, it doesn't take out the whole car's electrics either... that's got to be a ++ situation Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #361706 11th Dec 2015 2:41pm
nobbyclark
With so many people reporting battery problems and non-starting, is there an underlying problem? Or is it like the mysterious D3 air suspension: some drive to the moon and back and never have a problem, whilst others have nothing but grief.
"Just one of those things"
Post #361743 11th Dec 2015 5:43pm
miggit
It's not so much battery problems, rather it's electrical faults that are draining the battery, and would appear that the later ffrr's have caught up with the earlier BMW ones Shocked I personally am beginning to wonder if I haven't got the better built car, yes it's got its' electrical faults, but they don't seam to render the car useless over night Shocked Me thinks that Ford went on a cost cutting operation when they took over Sad Like the quality of the sound deadening in the tailgate, or should that be what deadening in the tailgate. And then there is the Tin Worm problem that a lot of newer cars are reporting Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #361784 12th Dec 2015 12:30am
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I went through this last year but never completely got to the bottom of it. It's been fine all year but has let me down twice this week already now it's gone cold. I think mine is due to the short 3 mile journey to and from work with lights, heaters etc on and the battery is not holding quite enough charge due to being drained several times. I now keep heavy duty jump leads, cteck charger and extension lead in the boot Shocked
Even though it has been tested ok it's Time for a new battery methinks. Sad
Post #361803 12th Dec 2015 9:39am
miggit
You either need to move further away from work, get another job, or take the poor old bus for a slightly longer journey every now and then Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #361811 12th Dec 2015 10:46am
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I hardly use my truck. I only work a mile from home so generally walk (unless it's raining, then I use the wifes petrol car). Meaning that I put about £30 of diesel a month in the fattie. And I only put this much in cos every week or so I make a special journey up and down a few junctions of motorway just to try and stop the battery getting knackered.
I've even had a thought of selling the old girl cos it seems such a shame to leave it sat on the drive. Big Cry
Post #361859 12th Dec 2015 4:24pm
Fish
I do try to go the long way home but if I work late, which is quite often, I tend to forget and autopilot home Rolling Eyes
I don't get out of the office as much these days either which doesn't help.
Post #361869 12th Dec 2015 5:05pm
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
The majority of problems will be masked by a new battery. The RR is one big teenage kid that cannot turn the lights off. I nearly sent myself mad trying to eradicate standby current drain. I guarantee most RR just get by because they are used regularly Thumbs Up
Post #363142 20th Dec 2015 10:33pm
miggit
Hmm, Me thinks you could be wrong there bud, mines more like a two year old....... very attention seeking, and tends to throw a tantrum if ignored for a few minutes Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #363176 21st Dec 2015 12:40am
Page 3 of 5 <12345>
