![]() | Home > Technical (L322) > Parking aid - LED light on switch is flashing |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
As above, turn the sensor on by pressing the button then go round and stick your ear against each sensor in turn. If you can hear it clicking it's working. The one that isn't clicking is the problem and it will either be a duff sensor or a broken wire. |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
I think I know which one is not working. The other day I parked near the bank and as there are no car parks in Yaoundé, I had to park on an elevated paving section and as I approached the wall, I pressed the button for the front sensor to beep but was too late as I bumped the wall. The front right hand side of the bumper, right where a sensor is located had been slightly scuffed but I thought no more of it.
I took the car to a garage in Yaounde that has a Paris Land Rover trained mechanic. He managed to push the sensor out of the bumper from the rear and we found two wires had snapped. Not having a soldering iron another garage mechanic simply twisted both of the wires together and then wrapped them in insulation tape. The sensors are now working again.
