Home > Maintenance & Mods (L322) > Tow Bar - Alco
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Tow Bar - Alco
I have the hitch pictured which I believe to be a Witter, would you knowledgeable chaps and chappeses know if this is ok for any Caravan as I heard you need a Swan neck for an Alco chassis, which I find hard to believe ?
 Many thanks
Paul
Post #362556 16th Dec 2015 10:22pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I am watching this with interest to see if there is any intrinsic reason why this wouldn't be suitable. Strength wise, I have used exactly that fitting on a Defender 90 V8 to pull broken down 44t attics from a standing start... uphill!
Post #362559 16th Dec 2015 10:32pm
Pvw10
Exactly, witter making a tow bar that doesn't tow mmmmm
If I can pull trees down then a tin tent should be easy Many thanks
Paul
Post #362561 16th Dec 2015 10:36pm
So long as it has a 50mm ball on it which is clean it will be fine for a caravan.
Folks say you need a swan neck as there can be clearance issues on a normal flange bar with the Alko hitch stabiliser, your ball an pin hitch may have issues in terms of how high the ball sits and how much clearance there is round the base of the ball once the hitchhead stabiliser is on.
However you could simply replace the ball and pin with an alko ball (available from eBay for cheap should be about £10) and all will be fine but I would try it with a van on first. Thumbs Up the actual bit which attaches to the car is totally fit for purpose so long as it is well attached Thumbs Up
Something like this. http://m.ebay.co.uk/itm/AL-KO-ALKO-Style-T...nav=SEARCH There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 16th Dec 2015 10:42pm. Edited 1 time in total
Post #362562 16th Dec 2015 10:36pm
Giantlandyman
"Tin tent"
Rolling with laughter Thumbs Up
Post #362563 16th Dec 2015 10:37pm
Pvw10
Thanks for that, great stuff.
I bought this hitch as very versatile with the pin and is actually longer from the car than a std one, about 100mm ( as I found out with parking sensors - bang into a wall) Many thanks
Paul
Post #362564 16th Dec 2015 10:39pm
