Home > Technical (L322) > Headlight no work
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Headlight no work
Last night when I started to come home from work, the right headlight blew.
Went to change it this morning, still not working Censored
Hi beam doesnt work either Question
Any ideas of where to look next greatly appreciated.
Thanks
Post #362993 20th Dec 2015 2:24am
Fuse maybe? Got - 2017 SDV8 Autobiography in Loire Blue
Post #362996 20th Dec 2015 2:34am
Fuses?
Post #362997 20th Dec 2015 2:36am
No fuses for the headlights, they are protected by mosfets in the LCM.
Having said that you could check fuses 4 & 9 which serve the LCM.
Are you sure the bulb failed and not the ballast?
You could try swapping bulbs left to right and see what happens.
Post #363011 20th Dec 2015 8:54am
The OP has an Aussie HSE so will most likely be “halogen” headlamp bulbs ndfi... Whistle Thumbs Up
Post #363038 20th Dec 2015 12:29pm
So he has. Thumbs Up No ballasts as a problem then but the filaments are still protected by Mosfets. Not sure why both filaments should be off in one headlight though. Possibly worth checking the earth to the headlight. Maybe even do a battery disconnect/reconnect and see what happens.
After that it would be worth checking on diagnostics.
Post #363040 20th Dec 2015 12:37pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Plug on the lamp unit? Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #363093 20th Dec 2015 5:16pm
Would say it's likley to be something specific to that light. There won't be a fuse or mosfet specifically for one side?
So as above check the bulb holder for corrosion on the contacts.
Check the pins for voltage.
Check for continuity on the ground wire between the body and the ground pin. There is nothing that can't be fixed with a hammer😜😜
Post #363110 20th Dec 2015 6:21pm
littlecub
Was some early bits of corrosion.
Cleaned it up,all good now.
Thanks
littlecub
Post #363204 21st Dec 2015 4:53am
