![]() | Home > Maintenance & Mods (L322) > An alternative to the Merc Sprinter bottle jack? |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
I got the Sprinter Jack and it's fine, I've used it a couple of times to lift the car to get the wheels off which it does with no fuss and it lives in the wheel well with the 20" full size spare no problem. I only got it for roadside wheel swapping and it is more than good enough for that task and IIRC it only cost me about 15 quid. Geoff |
| Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800
Thanks, fellas. I happened across a brand new one that was poorly advertised (so it didn't show up on usual searches) for £37, delivery included. |
Hey guys, while we're on this topic my Sprinter Jack sort of auto extends when stored not by the full amount but by 5 or 6 inches - anyone else had this and is there a fix? It still works OK and still easily fits in besides the spare wheel but its annoying. Geoff |
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435
Is it finding your spare wheel a little too exciting?
I think it's the Jack that's the problem with it's constant 6" erection - I will swap the Viagra for Bromide. Another helpful tip from the forum on an otherwise slow day |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
does it happen when the valve is closed or open Geoff..
Thanks Stan, IIRC it doesn't matter if the valve is open or shut, obviously I don't know how to "bleed" it and I have no leeches, in any case I'm not sure they would work. But I'll bet you (or someone) knows how to bleed the Jack without leeches |
open the valve and pump the handle for about 20/30 times and then close valve ....we used to get this problem on our bottle jacks when i managed a tyre depot and this procedure worked most of the time... ... - .- -.
This morning it's not raining so I got the Jack out and carried out this procedure, pretty much worked although the Jack did still want to extend a little bit - couple of Zip ties and its now sorted. Geoff |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
did you push down on the ram while you pumped it?
^^^^^^^ Yep pushed down the ram whilst pumping, only really came back up 30mm or so, just tie wrapped it fully closed before tightening the valve again - job done |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
This thread has more double entendres than a Carry On movie!
What are the options for an L405, if you don't want to grind the "ears" off a Sprinter Jack? |
| All times are GMT |
