![]() | Home > Maintenance & Mods (L322) > Coolant leak front near transmission clooler. |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Yeah I decided to get the eBay o ring kit for the X5. Went to get the X rings at the dealer-specal order. Useless place. |
OK any trick to burping the system? Book says fill to top where bleed screw flows. Seal, run to temp, let cool and recheck. When I recheck the float is all the way up. Heat doesn't come through unless I raise the RPM to around 1100. Then it goes cold at idle. I've done the squeeze hose trick to pump things through. |
Thanks jonboyairey. It seems to be coming along. Just needed a bit more RPMs, cooldown and more hose squeezing. Hmmm sounds familiar. |
Here is a list of the o ring sizes for the coolant hoses. Got the sizes from a seller on eBay that sells a kit.
May have missed the real leak or there was 2. I now see a leak from behind the fan cowling I assume. You can see a drip/stream coming from the opening where wires probably clip to. Went 200 miles yesterday with no issue. Today maybe 50 miles and a 5 inch puddle. Anything under that cowling other than radiator?
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
Can't help identifying the leak, but watching this thread with interest as mine seems to be doing the same, although the leak is worse/more noticeable when parked nose downhill |
Haven't been able to reproduce the leak. Brought engine up to temp, let it idle for 20 min, ran around the block. I've popped the plastic rivets off the cowling and pealed it back. Only see a small wet area between 2 fins but can't make it drip.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Take off the cowling, if yours is the BEHR rad then almost guarantee it is seeping out through some hairline cracks that only open up when hot.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Is there a known fault on Behr radiators Howard ?
As far as I know my BEHR rad was installed when car was built.
Thanks Smutt, yes I have found the apparent leak just about 3 inches down from the top. Right now it is hardly even a seep. I'd drive around 5 miles, 10 miles and check it and see only a wetness at some fins. It must open up on the highway with more pressure and wind. As soon as the outside temp hits 40 f I will clean it and JB weld it. Normally I would put a new radiator in now but its too cold. It just needs to hold about 2 months. |
Thanks for posting on this thread Howard !!
I found fcpeuro.com does offer parts with lifetime warranty including wear items. Their Behr is $247 shipped in the US. About $50 more than the Hella I could get from Rockauto.com but it would be the last one I would need to buy. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1382 ![]() ![]() |
hella behr is the same company |
