Home > Maintenance & Mods (L322) > Replacing rear plastic trim next to rear windows?
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi,
No idea what they're called but the big black plastic trim next to rear windows has a bit of damage and seems unlikely it can be repaired so what are the they called/part numbers please?
It seems there are a few bolts from the inside holding them on so hopefully they can be replaced easily.
Post #363362 21st Dec 2015 9:37pm
They are held on with clips from the outside, four or five at the front edge and some more inside the tailgate opening, they are the use once type clips, so you will need some of them as well...
Just ring Dan at Duckworths, he'll sort you out....
Called "D" pillar trim... Pete
-Click here for Thread-
Post #363372 21st Dec 2015 9:46pm
rich89
Great. Thanks
Post #363384 21st Dec 2015 10:12pm
rangie47
hi rich ,you mean the D pillar external cover 2007 tdv8 se ,stornaway grey
Post #363396 21st Dec 2015 11:03pm
