![]() | Home > Maintenance & Mods (L322) > Filling up! |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
This may / may not be related. I had an Audi A5 rental car for a couple of days this week. When I was filling it with Diesel last night at the local garage (it was raining heavily and a bit windy) it took ages to fill, pump kept clicking off and very slow to fill.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
no problems filling mine tdv8 l322 Cheers
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Keep an eye on it, the senders can start sending erroneous readings to the cluster so registers the wrong amount of fuel it sounds like it could be under reading the amount of fuel in the tank. You are right in that full should be about 97L so if you have only managed to fit 60L into the tank there would have been about 37L left in! Which should give a range of about 120-140 miles. There is nothing that can't be fixed with a hammer😜😜
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
That's weird as I can never get near the amount of fuel my old td6 took to fill up , is there anything that can be done to make them read the level better ? |
i noticed that mine clicked off filling at 60L last time I filled up but I persisted and got another 20L in.
Oh well, an annoyance I can live with for the time being! |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Looks like you have an 11 plate bought recently?
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
The problem seems to be with all Range Rovers. Mine fills up but only reads just under3/4 but when it reaches toward empty it really is nearly empty, once when I filled the needle went to the full mark and I thought it had fixed itself but next time it was back to just under the 3/4.
Scooter-s8 Member Since: 30 Jun 2014 Location: Fife Posts: 3 ![]() ![]() ![]() |
Always had this problem its a real PITA to be honest. Just have to go slow and hold at an angle. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
It's like pouring a pint, the faster you go the more it froths up...... end result a tank half full of foam..... and by the time you've paid for it..... 3/4 full tank of fuel. The only way you'll get a full tank is to fill it slowly, and it's got more than 1/2 a tank to start with, filling from empty you don't stand a chance, unless it's one of those really really slow pumps.... that..... take....... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Mine varies. For instance yesterday filled up with nozzle at full delivery and inserted right way up. |
The L322 has a tortured part to the tank from the filler, it's a fact, why did they fit that restriction in the top to stop you using commercial fuel pumps............ cos they knew that the tank wouldn't handle the high flow and spit it all out.
davidjpowell Member Since: 11 May 2014 Location: Doncaster Posts: 111 ![]() ![]() ![]() |
Could have done with this thread on Saturday.
