![]() | Home > Technical (L322) > Just Bought A 2011 4.4 TDV8 Vogue SE - few queries |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
I always release it manually too (in the hope of it being less likely to break). |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8784 ![]() ![]() ![]() |
The standard kit is plenty loud enough and decent quality. The 1200w system is better, but tbh most of the time i doubt you would notice the difference |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Is there anywhere I can download an owners manual from ?
Should be able to get it off topix There is nothing that can't be fixed with a hammer😜😜
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
Looks great - its easy enough to spray both the bar and the foglight surrounds yourself, just then the cost of a rattle can or two. It is a bit of a pain getting the cover off the bar to spray it, I did it although it tested my patience a bit but worth the effort. I used Alloy 5 Wheel Silver (Simoniz I think) and had no problems also masking the foglight surrounds is a bit tricky I actually used elastic bands to get the curve done neatly. Geoff |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
You are a brave guy spending so much money on something you have not seen |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
^ refundable deposit should take care of that |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8121 ![]() ![]() ![]() |
I bought my last L322 & my current L405 from photos
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Looks fantastic.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Congratulations Mark....shall I take it for a run round Tong for you just to iron out any creaks? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Nice one Mark.
Cheers all.
1200W one was an option. |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461 ![]() ![]() ![]() |
What I suspect you will notice most is the smoothness of the drivetrain, particularly the gearbox - oh and just how few revs you are pulling at motorway speeds.
