Home > Technical (L322) > Front suspension is down and rear is up
6029 king Stephen
United Kingdom 2008 Range Rover Vogue SE TDV8 Rimini Red
Hi all,
We went out today to look for a waterfall off the beaten track in Cameroon but were unsuccessful. During the trip, so of the roads were decidedly rough and I had raised the suspension for limited times before returning it back to normal mode. There was one track that looked bad but when I tried to raise the suspension the lights were flashing but the front didn't seem to rise and when I flicked the switch to return it to normal height it reacted immediately, suggesting that the suspension hadn't altered at all. Deciding to go home, the only way out was over roughshod roads with some potholes and other places where the road seemed to have disappeared and I had to come to an almost standstill before crossing them.
Over the next 30 kms or hour or so, the ride from the front suspension was getting worse and worse with it seeming to "bang or thump" whenever we went over the slightest pothole and when their were highs in the middle of the road, that vehicle seemed to be bottoming out. There are no laybies on these tracks and they are barely wide enough to drive down so it took some times to find somewhere to stop and investigate. When I finally stopped and got out, I noticed that the front of the car was much lower than the rear. There was also a hissing from the front left wheel area and at first I suspected a flat. The hissing stopped. When I started the engine, it sounded like the suspension was trying to raise but the car was not lifting. Turning off, I could hear the hissing and wondered if a pipe connected to the air suspension had split or had snagged on something. The suspension did not change and I had to drive very until we reached the main Tarmac road. The car is sitting very low at the front and very high at the back. Any ideas?
Thanks,
Steve
Post #364136 27th Dec 2015 7:35pm
There is a thread on it here http://www.fullfatrr.com/forum/topic15626.html
Sounds like you have a leak on the pipe to the front airbag. Can be repaired with a push fit connector. Thumbs Up
One idea at least Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #364137 27th Dec 2015 7:48pm
proser
air leak in the left air bag. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #364143 27th Dec 2015 8:54pm
6029 king Stephen
There is no Land Rover dealership in Cameroon despite there being lots of Land Rover products being driven here. In Yaounde we are fortunate to have a garage that has a French bloke who was trained by Land Rover in Paris. I took the car to them this morning and after suspending the car in mid-air it was evident that the left hand air bag on the strut had failed and was deflated whereas the right hand one was hard and the rear ones very hard.
I told the garage that I will order the parts from UK and have them fitted by their garage. They told me that they could get the two struts for FCFA 750,000 (approx £850!) but I saw on the internet that they are around the £200-235 mark so I will get some quotes and get a them couriered to me. Sadly the vehicle will be off the road for a fortnight but hopefully after that time, we'll be back travelling around the country.
Thank you for both of the answers - at least one of you was right.....
Cheers,
Steve
Post #364235 28th Dec 2015 4:35pm
Think Island 4x4 are the cheapest at the moment and AFAIK they will ship to you.... buy the Delphi ones, they are OE Thumbs Up Pete
Post #364274 28th Dec 2015 8:20pm
6029 king Stephen
Thanks Pete.
I've looked already and they are just under £200 each. I will call them tomorrow to see what else might be useful such as nuts and bolts given that my car is 12 years old and they might not have been undone until now.
Would you (or anyone else reading this) consider the suspension on the L322 to be its Achilles Heel? This the second suspension repair I have carried out in 8 months that I have owned it and 3 months of that ownership, the car was in a container on board a ship from UK to Cameroon.
Cheers,
Steve
Post #364305 28th Dec 2015 10:27pm
Not specifically, no.
If yours had the original struts on it then it is probable that the rubber had hardened and degraded over the 13 years since they were fitted so if you fit OEM then you should get a similar life out of the new ones.
the compressors fail too, but these are replaceable with out too much difficulty, again they wear out. There is nothing that can't be fixed with a hammer😜😜
Post #364321 28th Dec 2015 11:20pm
n1cktdv8
been reading a few posts on height issues. Mine is still slowly dropping at the rear. Equal drop each side which makes me suspect a pipe linking the two rear bags - is there such thing ? Is this where I put the car details and a bit about myself ?........
Post #364334 28th Dec 2015 11:57pm
@ nick
It shouldn't happen (awaits correction Twisted Evil ) because there is a valve to each corner and at each corner, so logic would say that they both have to be leaking? You should be able to disconnect the reservoir and the compressor and the thing should stay "afloat" with the engine/ignition off.
More likely it is the car "levelling" itself, or taking "correction" from the height sensors, so maybe it wants calibration. .
Post #364353 29th Dec 2015 1:32am
n1cktdv8
A few months back it hit the deck at the rear and I got it back up after a few hours of praying and telling the old girl she's my only car - happened the same day I looked at a 4.4 tdv8. It's been good since but if I leave it for a few days it'll drop gradually, just at the rear. If I'm 100% honest I think it's the rear offside that has failed as it seems to be lower than the near. I'm going to get it all measured first. Then queue the music......I am borrowing a mates ramp while he is closed over xmas/NYE and seeing if I can isolate the issue. Is this where I put the car details and a bit about myself ?........
Post #364383 29th Dec 2015 1:09pm
Weegie
Steve If it isn't too late I would suggest you order new bolts for the bottom of the struts. There are four and I found they were a bit of a pig to remove. The danger is damaging them and, being at such a distance, for the extra cost even if you end up not having to use them. John
GAP iiD BT-Sold
Post #364385 29th Dec 2015 1:27pm
6029 king Stephen
I have ordered the parts from Island 4x4 for £574.98 including courier delivery to Cameroon. I hopefully include a photo of the car and you can see how much it has lowered at the front. When we exit our driveway, the car bottoms out as we go onto the road. I have a special route to the garage to avoid pot holes but it is not easy. The front end bounces up and down if I go over anything that is not flat.
Happy New Year!
Cheers,
Steve
Post #364755 1st Jan 2016 9:31am
6029 king Stephen
All fixed now. The next thing to break? The bonnet release wire has snapped where it meets the plastic connector under the bonnet. I now have to use a pair of pliers to pull on the wire but because it is too short, I have had to do without my clutch foot rest plate. I'm back in the UK in February for just over a week, so another item to add to my list.
We're off to the beach for the weekend today - about 4 hours away so I am looking forward to that journey. Last week I drove 850 kms with 320 kms of that being off road on forestry roads with a few hairy tail slides thrown in. 80 kmh is fine for the straights but 60 kmh is plenty for bends especially when the top surface has grit like marbles to help logging trucks keep to time.
Regards,
Steve
Post #368378 22nd Jan 2016 7:18am
