![]() | Home > Maintenance & Mods (L322) > Second failure(s) |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Took the fatty for her first MOT since I've owned her. I was quietly confident that all would be well and maybe I'd get an advisory at the worst. Oops, wrong. It failed on the front nearside radius arm ball joint and both rear hub carrier lower bushes. I managed to change the radius arm with no issues but I couldn't shift the bolt through the lower hub bushes. So she's booked into Green Oval in January for them to to it. Boo hoo. |
Yup cheers for that. The biggest issue for me is having to work on the drive and not being able to get it in the air to give better access. Also they will have the correct pullers rather than faffing around with sockets and screwed bar. I did ask them to check out the upper bushes while they had it stripped down as at £30 per side extra it will save on labour in the long run. 👍 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Just make sure they use genuine parts, there are some very cheap bushes going around for about £6 each, you can imagine the quality..... |
Green Oval will only use genuine parts. He told me this on the phone when I booked it in. Apparently he has known the top bushes (which are supposed to be an interference fit) to work their way out. Not good. Trying to save a few quid on an important suspension component could end up costing hundreds if it fails dramatically. I dread to think what the outcome may be. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Lower bushes are available as part of the new LR Trade program, at £19.51 + VAT. Even cheaper than the OEM bushes |
What is the LR Trade programme please? |
