Home > My Range Rover > 2009 Autobiography
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
2009 Autobiography
so deposit paid on this today , having it inspected just to make sure its mostly above board, some of the photos in the ad showed the rear left air spring was sagging but Ive been informed thats fixed. Fully loaded with everything I wanted except a towbar , but that's an easy fix.
Post #364423 29th Dec 2015 6:45pm
mjdronfield
Looking good fella !
I'm in the process of going from a 2003 td6 to a 2011 4.4 TDV8 so am too looking forward to a new ride....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #364427 29th Dec 2015 7:02pm
Nice looking 3.6 that. Good colour combo Thumbs Up
Starter for 10 and £50 is the two top intercooler hoses, which are simply held on with 2 jubilee clips each. Will stop you getting stranded when the originals let go (which if they haven't been changed yet will at some point). There are a few silicone kits around which are worth a look too Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #364433 29th Dec 2015 7:46pm
Eric Cartman
Starter ? do they go often in these, or do you mean for starters ?
52,000 miles on it and it was serviced at 49,000 so I won't be servicing it for a while, aside from turbo hoses, anything I should budget for needing doing in the next 6-12 months.
Post #364437 29th Dec 2015 8:04pm
Meant for starters..... So don't panic Thumbs Up
Rear calipers can stick, but are cheap too.
Would get the diff and transfer box oils changed, and a transmission oil and filter change for peace of mind. There is nothing that can't be fixed with a hammer😜😜
Post #364464 29th Dec 2015 8:56pm
Eric Cartman
fluid change was going to be done anyway, anytime i buy second hand 4x4s its a decent idea. Hopefully it all checks out and I can go collect it next week or so.
Post #364465 29th Dec 2015 9:10pm
pld118
northernmonkeyjones wrote:
Meant for starters..... Would get the diff and transfer box oils changed, and a transmission oil and filter change for peace of mind.
Mark, have you changed the transmission oil and filter on yours yet, even at such low miles/ young age (I've changed the front/ rear diff oils and the transfer case fluid but not the transmission oil/ filter)?
Post #364647 31st Dec 2015 12:35pm
not got round to it yet Ryan, I am going to get them to do the diffs and trans box when it goes in for its next oil service. pondering on the box, its just ticked over 40K so may leave it until the next oil change at 50K as we aren't doing so much towing with it as yet. There is nothing that can't be fixed with a hammer😜😜
Post #364664 31st Dec 2015 3:47pm
pld118
Cheers Mark Thumbs Up
Post #364708 31st Dec 2015 8:25pm
Eric Cartman
Right lads , have a little bit of an issue, had a check done on the car from totalcarcheck beforehand and all came back clear, due to a slight wobble with the dealer thats now resolved about the V5 being present I got a little worried and did a HPI check, now between the MOT data and and the HPI check data I have the following table of mileage , Im inclined to think that the one highlighted in orange is a mistake , but just to put me at ease.
Is there any known case of a 2010MY being clocked ?
is there anywhere else that may log the mileage that I could possibly check to give me a better idea ? (in Ireland we basically have nothing to log mileage so its even a miracle that I got this as far as I'm concerned)
Also I asked LR about the service history, but they lack it, dealer apparently has all the history and Ill be checking and calling before handing over the money but Im wondering is there any records stored on the key or in the car I can have read with a computer.
Post #365124 3rd Jan 2016 8:23pm
i'd say it was a mistake..the '54***' should be '45***' i reckon... ... - .- -.
Post #365130 3rd Jan 2016 8:34pm
Has been very little used over the last few years by the look of it.
First couple of years had higher than average milage, but the last couple has only logged 1-2k per annum, so stans comment above seems fair.
I seem to recall that the milage is logged in several ecu in the car (could be wrong though) though knocking 10k miles off a car would have some benefit to sale price it has a fairly average milage tally in any case so wouldn't make a whole heap of beans money wise. The only reason i could think someone would bother would be to reduce it down so it is under a contracted milage on PCP. There is nothing that can't be fixed with a hammer😜😜
Post #365140 3rd Jan 2016 9:09pm
Eric Cartman
was inherited by the last keeper in july 2012 so id say the new current owner is a low mile user, or its been passed around to a few dealers, its being examined by dekra this week and ill be double checking everything so ill know soon enough whats up with it.
Post #365150 3rd Jan 2016 10:04pm
Eric Cartman
ok so its all been inspected and has come back with a mostly positive report. Paint is all original and hasn't been touched up , electrics all good, driving all good. tracking slightly off but its not as a result of any suspension component failure.
engineer said theres some evidence of oil at the top front of the engine and a little evidence of oil at the gearbox but neither look new and it isn't dripping or losing fluids while running.
any suggestions of if these may be horrifically expensive or is there any simple and obvious things that may be causing this ?
Post #365492 5th Jan 2016 9:15pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Evidence of oil from the engine, evidence of oil from the gearbox - that seems to be a classic set of issues Smile 12 4.4 TDV8 Vogue
Nara Bronze / Arabica / Ivory / Piano
07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #365866 7th Jan 2016 3:17pm
