![]() | Home > Technical (L322) > EAS Conundrum, could it be the LCM at fault? |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi dt could be lcm would have a look for water ingress.
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
Might be worth checking if you have an intermittent connection and earth. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
As I understand it the LCM logs faults but doesn't cause them, the problem will be somewhere else, maybe a leak or faulty height sensors, chaffed wiring.... etc Pete
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
This sounds like a leaky bag playing a game of "How not to be seen!" I seem to remember similar symptoms when I sprang a leak at the front. Not sure that the headlight has anything to do with it - possible headlight failure considered safety feature by car therefore shuts down other parts such as EAS (e.g. low brake fluid sensor will disable EAS)
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
^ +1 John
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
Are you seeing valid height sensor readings on all corners?
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Many thanks for the ideas and suggestions guys, much to ponder and investigate.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
it may be unrelated but I had an issue with bulbs on my 54 plate.. The build would flicker and sometime stay on or sometimes go off. Turned out to be a ballast on it;s way out.
Well, initial update.
Not sure on this but worth a check, there is a "re-enable EAS" choice on the IID, don't think you have to do it after clearing faults but it can't hurt.... |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Unnecessary quote removed
Hi Weejock, the problems had started to rear their head after two trips through deep floods on the way back from Carlisle, the weekend of the serious flooding. There was a lot of dirty water in the footwell which I dried out and cleaned up. Have noticed though that there has been small quantities of clean (rain) water getting in to the well, but they have been below the compressor, so I think the troublemaking water has got in through the grommet hole. Have checked the boot seal and found a split which would justify the small amounts getting in, so a new tailgate seal is needed first.
If you have had water in the foot wells then the BECM which is under the passenger seat, in a hole, will have got wet or been covered in moisture as the carpets dry...
I think I've been lucky (touch wood) in that it's only the spare wheel well that filled up with water. Just been out and checked the front and rear carpets and they seem to be bone dry. Gonna do a more thorough check tomorrow (if this |
