![]() | Home > Off Topic > Theiving little ***** |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Hi there -
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
If the car has an alarm you can wire in an extra door contact switch behind the plates .
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Cheers Guys,
Stick on plates may be an option... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
was looking at that, and it would be ok at the rear but the front has only got fixing lugs.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Hi, here in France plates are riveted to the car, so you got to drill them out. It is even required by law. Might be a solution |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
Seriously good advice ![]() |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I've seen some UK plated Jaguar sport cars that actually have the plate number painted on the front. Is that an option? It's hard to steal paint once it's been used. |
Afaik , once they changed the laws to have who made the plate also included on the license a lot of the sticker makers that used to supply them for e-types etc had to stop *
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
What I do with all my cars is fill the screws with aradite once you have tightened them. A chance then can't quickly unscrew them. The fronts can be pop riveted which is also a good detterant.
Fortunately for him he is in devon with the ex deputy coroner for leicestershire, so has a pretty good alibi if anything has happened over the last week.....and the car has been parked up outside the house of the assistant coroner for Derby since wed morning (somehow we know a lot of coroners) so if anything has happened then the cars whereabouts is noted well enough as it hasn't moved. There is nothing that can't be fixed with a hammer😜😜
Sounds like a "dead" honest alibi |
Thanks, Ian. I finally got the idea that letters represented model years and then they made the whole think a lot more confusing. |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
3m double sides foam tape |
