![]() | Home > Wheels & Tyres > wheel geometry |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Here's an interesting one.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
There does appear to be a difference, the later cars are different depending on the engine as well....
Thanks Pete
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Where did you take it? There is nothing that can't be fixed with a hammer😜😜
Formula 1 in Burton on Trent |
Check the settings on the sheets Pete posted and see if they are in tolerance. There is a difference but its not massive and if they are near the centre of the range then it should be OK, the main one for the front is the Toe setting, they can't play around with the camber and castor on the front wheels, it needs a special too to adjust the top mount. The rear camber and toe can be adjusted though.
It was done on an all singing and dancing "Hunter" machine. Just spoke to someone who knows the machine and he says that its worth getting it re-checked.
