Home > Technical (L322) > Question about in car telephone
Andy
There are buttons on the steering wheel and to the right of the TV screen for a phone, but no actual phone is installed.
Are these buttons standard fit or only fitted in conjunction with the handset?
All I have in the centre console under the lid is a big open space!
Post #3642 10th Mar 2009 7:45pm
dantheman
What year/spec again noddy?
Most are compatible via cradle or bluetooth...
Post #3644 10th Mar 2009 8:09pm
Andy
2002 Vogue 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3645 10th Mar 2009 8:27pm
when you lift the centre console has it got this a pin connector
And if you check under here when lifted for any wiring
if so you will need one of these
which in turn will allow you to do this
Hope it helps Thumbs Up
Post #3647 10th Mar 2009 9:21pm
Andy
I
MICK wrote:
when you lift the centre console has it got this:
haven't got that moulded section that holds a phone cradle - it's just a big flat open storage space.
I have a nokia 6230 as well. If I get the insert and the cradle, is the wiring already there for it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3648 10th Mar 2009 9:24pm
dantheman
That's the badger - like I have!
I connect via bluetooth at the moment - for want of a phonebook facility... Whistle
Post #3651 10th Mar 2009 9:40pm
That i am not too sure about Noddy , on one of the pic's where i am pointing , check and see if there is any wiring there you should be able to feel it with your finger.
Post #3655 10th Mar 2009 10:07pm
Andy
Thanks for the help.
Just checked - there is wiring!
What would you consider reasonable for a cradle? There's a couple on ebay for around the £50 mark. I will also need to get the pan from somewhere- unfortunately, none on ebay. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3657 10th Mar 2009 10:28pm
I recently sold my 6230 cradle to an Italian (in Italy) for £120...what a numpty! Discovery 4 HSE
Post #3660 10th Mar 2009 11:19pm
Andy
This is what I have at the moment (not my car- sample pic):
I've found this on a parts site:
But comparing it to yours, the middle section is missing, like it's a seperate part. Yours looks like one complete moulded section. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3662 10th Mar 2009 11:47pm
will check tomorrow in the daylight Thumbs Up
Post #3663 11th Mar 2009 12:15am
The centre section IS a seperate part , i have been looking at Smarteq.co.uk to see if they had the cradle assy that would fit it , but no luck as of yet .
Neutral
Post #3671 11th Mar 2009 2:24pm
Andy
I called a dealer today to enquire about the parts required. He told me that although the car has buttons for the phone on the steering wheel, and wiring in the centre console, I would be wasting my money buying the relevant parts as it will not work Neutral He reckons that the buttons etc were all fitted at the factory as a matter of course. Before he told me this, I asked him where the mic goes, but he didn't know.
Can anyone confirm that they have fitted this kit successfully? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3674 11th Mar 2009 4:44pm
Sorry to say that I have also heard that its a hell of a job to do. Discovery 4 HSE
Post #3677 11th Mar 2009 5:39pm
StevieH
Noddy
My car came with the full Nokia set up installed, unfortunately it was for a Nokia 6230 or the likes and I've got an N95 8GB which I use as my mp3 player aslo to save me carrying pnone and ipod. What I did was bought a cassette adapter and pluged the phone into it and had handsfree phone and mp3 through car stereo for a fiver!
Today however I removed the Nokia set up and installed a Parrot system, pretty good but not sure if it is £250 better than what I had
Post #3695 11th Mar 2009 9:01pm
