Home > Technical (L322) > Reversing Camera fault
Have done a search but to no avail , anyone had any problems with the reverse camera just since yesterday it went on the blink and just shows a black screen when i go into the self test mode all i get is this ........ Yet the RSE works fine ......
Do you reckon this would need to be a dealer fix ............
Thanks
Post #36473 17th Nov 2010 9:57am
do a battery dis-connect/connect maybe mick... ... - .- -.
Post #36479 17th Nov 2010 10:19am
Sometimes it works scarey when i do full wheel lock to lock , other times it stays on longer than it should when in park ........
Post #36480 17th Nov 2010 10:23am
Sometimes it's so much less hassle having a base spec SE model Whistle
Post #36481 17th Nov 2010 10:24am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: Reversing Camera fault
Whistle Yep - let them fix it....after you have p'xed it Wink
Post #36483 17th Nov 2010 10:27am
Can't complain first main fault in 5 and a half years ...... Thumbs Up
Post #36484 17th Nov 2010 10:28am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Is the video input in the boot easy to get to.. I'm thinking plug in something like a cam corder to it and see if it works then... At least you would know if its the camera or the system then. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #36538 17th Nov 2010 3:37pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Have u sorted out the rear camera problem yet Mick? '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #46448 18th Jan 2011 9:33am
