Home > Technical (L322) > Detachable Tow bar
Andy
Detachable Tow bar
Another question Smile
I decided to take the tow bar off today as I don't plan on using it (yet) - I found the red keys in the boot but they wouldn't go into the lock at first. Likewise, I couldn't turn the knob clockwise (I discovered this before reading the manual and thought it was seized!)
A bit of WD40 and a tiny screwdriver to prise the lock aperture cover open and I managed to get the key in. I can now turn the knob clockwise, but it only pulls out slightly.
The handbook says insert key, pull out and turn clockwise and the bar will drop out. Now, since I've loaded it with WD40, I can now turn the knob without the key - is this right? If not, I'm guessing that the tumblers inside the lock are now stuck in the unlocked position, probably due to me semi-forcing the key in Sad
Worried that the tow bar will now either (a) drop off or, (b) be stolen, I've unbolted the housing from the chassis and removed the lot until I can figure out how to fix it.
The handbook isn't that clear in it's explanation of how it works - so, in short, my question is: can the knob be still turned clockwise without the key inserted and/or is the key there just to enable the thing to be pulled out?
Post #3273 2nd Mar 2009 8:41pm
Andy
Anyone? Shocked
Post #3373 5th Mar 2009 12:19am
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Dont have a clue re this Sad
Post #3375 5th Mar 2009 1:47am
Andy
Come on guys- can someone nip out to their car and just check to see if that knob can be turned and/or pulled out without the key please!
I've found a plastic grommet on the tow bar, covering a circlip. Might have to be a strip down job later if no-one can assist.
Post #3476 7th Mar 2009 11:04am
Noddy, like you say I'd need to go out and play with it to check, but with my right hand in plaster I can't do anything right now.
Can someone else help Noddy out? Discovery 4 HSE
Post #3480 7th Mar 2009 12:13pm
Shout on Big Ears ........... Rolling with laughter Rolling with laughter
Sorry could not resist , plus can't help either don't have a towbar .........
Post #3486 7th Mar 2009 12:29pm
Andy
Yawn 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3649 10th Mar 2009 9:28pm
Andy
Post #3739 12th Mar 2009 8:27pm
Come on chaps....... Embarassed Discovery 4 HSE
Post #3743 12th Mar 2009 10:04pm
dantheman
I'd love to noddy - but made the mistake of assuming that detachable towbars were de rigeur on the Vogue, and bought mine not realising the contrary - no towbar... Censored
Sorry I can't be of any help dude! Embarassed
Post #3750 12th Mar 2009 11:18pm
Noddy, despite a broken hand I am going to try and find an answer for you on my car later today.
Hope the wife doesn't see me trying, she'll go mental! Discovery 4 HSE
Post #3756 13th Mar 2009 12:19pm
Do you blame her , Play about with the car with a broken hand ....eh , eh Whistle Whistle Thumbs Up
Post #3760 13th Mar 2009 12:27pm
Full fat not diet
I can just imagine it Rolling Eyes . "If your hands ok to start playing around with the car then you can do this list of jobs i have got................" - emergency measure may be needed here - if all else fails break your other hand !!! Rolling with laughter Rolling with laughter
Post #3764 13th Mar 2009 12:51pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Checked mine today and here goes:
No key in the knob will turn, but only about 10mm, the red marker on the knob will be at the bottom of the green marker on the hitch.
Insert key and turn it 1/2 a turn clockwise.
You will now be able to pull the knob out and turn it clockwise until the hitch drops out.
Hope that helps.
Post #3855 15th Mar 2009 9:41pm
Tried mine withouth the key only.
It will not pull out or turn. Shocked Discovery 4 HSE
Post #3856 15th Mar 2009 10:15pm
