Home > Maintenance & Mods (L405) > Anyone Swapped Exterior Bright Trim For Black or Vice Versa?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
I've got a near full set of replacement trims for the lower doors, rear bumper where it meets the quarter panel and trim in the front bumper, all in black to replace the silver I have now, has anyone removed any of it, so they can give me some guidance please? LR TOPIx shows simple trim removal tool but they look well clipped in (I have the full door lower trim so can see the think insert fixed into the plastic piece) and I don't want to mark the paint prying at them with a removal tool?
Thanks
Carl
Post #365419 5th Jan 2016 5:06pm
Did the new trim come with new clips ?
I replaced my side fins & the new ones were a good guide - I still broke a few clips removing the old ones, but didn't really matter as I had new clips.
The fins required a good firm tug, but came away fairly well - you should be able to pretty much tell what to do from the new ones - including whether there are any hidden slots, or whether they should pull straight out.
Good luck - be brave Thumbs Up
Post #365449 5th Jan 2016 6:19pm
So are you going for this look ?
I couldn't make my mind up - so still have the 'pikey stripe'
There's a good page here showing a few different combos Thumbs Up
Post #365455 5th Jan 2016 6:26pm
carlos50
Indeed, but black wheels also.
The trims come with lugs that snap in rather than separate clips, I'm worried I mark the surrounding paint with the trim tool
Post #365470 5th Jan 2016 7:27pm
Put a rag between the tool & the paintwork
Post #365690 6th Jan 2016 6:12pm
