![]() | Home > Technical (L322) > New knocking, clicking noise on TDV8 4.4 2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
loose heat shield over the prop ?. ... - .- -.
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
Thanks. I will check that out but the noise sounds more mechanical that's something loose. If that's makes sense. 2012 4.4TDV8 VSE
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
I've just had something similar. Turned out to be a loose backing plate for front offside disc brake. It's rotted through at the mounting bolts. 4.4 TDV8 Vogue Baltic Blue MY11 |
