![]() | Home > Maintenance & Mods (L322) > Transmission sump pan bolts |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i used ebay, and bought m6 stainless socket head bolts, 20mm long. these have a normal allen key head, as opposed to torx. some days I hate torx, others a don't mind so much. these should not be that tight, but I had mullered a few trying to get overtight bolts out, and had to resort to using a sharp chisel to knock a few loose. just make sure you spray the old ones, and that you are definitely using a t27 torx spline/key you can buy these individualy on ebay, again, for about £5 all bolts are undoable with an allen key, except the couple obstructed by the trans cradle bar. However, I would recommend you use the T27 mini spline socket, shaped like this, http://www.ebay.co.uk/itm/T27-TORX-KEY-BIT...uF62PtFXfA not necessarily this make, choose your trusted make, some of the bolts need a universal joint..
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Cheers for that. Didn't want to go down the torxs route again. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i agree, make sure it's a T27, a T25 will fit, until you have a tight one and it'll slip and ruin the head. |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I cannot understand the 'Torx revolution' they are terrible things and it is difficult sometimes to get the right size and do not get me on 'rounding off'.I struggled to get out several of mine,the hardest ones to get to as usual.Just took one to the local hardware supply and got hexagon head although I had to put 2 of the torx[or was it 3] back as there is a couple of narrow channels that the hex wouldn't go in.I did however repair the gasket with hoylamor without problem as I only bought 1 gasket and when I do another drain I can remove it again,clean then put on new gasket. |
they're better for use with power tools on production lines - all about speed of assembly.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
Iirc the Philips screws you mention were invented by Philips to speed up there production lines years ago .
I think so yes, it was to do with early powertools and 'stanley' push action screw drivers. They didn't have automatic torque limits so the were designed to cam out to stop the bit breaking or stripping threads if you tried over tightening them. It was an improvement over slot heads at the time. With modern pre-set torque power tools Torx is far better - i think they came from the aviation industry. Problem is someone gets there before you and uses the wrong bit. ![]() |
Have never had a problem with screws,a pz2 or pz3 or ph2 or ph3 are almost exactly the right size and rarely a sloppy fit.Torx however seem to be different with so many different sizes,my friend lent me a very comprehensive set and I could not get an exact match ,either too slack or too tight,i ended up using the tight one and literallt had to hammer it on to get hold,which I ended up giving several a good hammer as I was loosening as they were very tight and feared stripping,then used the slack one when I had got them loose.! |
Did the deed today... I challenge any one to do this over a piece of white carpet and not make a mess !! Luckily I had a garage with a ramp. Ditched the tork screws I took off and replaced with M6 16mm allen head screws and washers, stainless steel of course. Did the engine oil and filter as well. Of course this is a Range Rover so the engine management light which I haven't seen in two years came on as soon as I left the garage..... GIVE ME STRENGTH !!
Looks a bit rusty,i spent an hour or more sanding mine down and got some paint on it,looks great too ! |
Patenation...all the rage in the Antiques world..... |
they don't rust, unless they DONT leak!
