![]() | Home > Technical (L322) > HELP. strange gearbox behaviour. Should I drive it? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I know nothing about the td6 gearbox, but have heard of torque converter shudder/shimmer on this forum. like a 'cattle grid' sound. but what I think, is fluid level -as it happened when fluid may have not been pumped, when at a steep angle etc. I guess you could do no wrong, reading up on checking/filling the fluid level. |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169 ![]() ![]() ![]() |
Thank you. Checked oil last week and checked this morning again; filled in another 300cc and nicely peeing out at 39C after shifting gears thoroughly. After that test drive: not a real difference |
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
Yes it needs a replacement torque converter. Or whilst it is out you can do a complete rebuild.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
1. Tc (replacement is likely to be more like £900?!)
GM torque converter rebuild is about £100 from vanmatic or jpat.
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 115 ![]() ![]() ![]() |
Are you holding on the brake until it is properly in gear, or going into reverse on the roll / hitting the power as soon as the lever is in position?
@ IPWN. yes sorry I was talking about getting a new one. Not sure I'd trust a rrefurb?
thanks for your replies.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
just thinking outside the box as it were, have you considered the transfer box could be the culprit, possibly a stretched chain in the transfer casing, I haven't seen the inside of the TD6 transfer case as it has the NV225 box on it rather than the Magna Steyr on the TDV8 and discos, but I seem to recall there can be instances of the chains stretching....
Really out of the box thinking |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
@ Rangie4fun, at the overhaul, did they CHANGE your oilcooler, or did they only flush? If only flush, there come some old metal parts back in your recon gearbox, had it often here at my clients..., TC comes mostly not BRANDNEW, only also recon...., best wishes, Uli from Düsseldorf, only 100km from Maasmechelen. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Yes! brand new TC and oilcooler (LR genuine)
Have a search generally online for NV225 failure there are a few articles out there where folks have had the chain stretch.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Were the wheels straight when you were reversing? I had a shudder / wheel skip which Craig thought might have been a stretched chain. Turned out to be water in the transfer box oil. It caused the central diff to partially lock up when it shouldn't have.
