![]() | Home > Technical (L322) > Glovebox opening |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
To open the lower glovebox I have to give the drop down door a firm tap before the switch will release the lock. The upper one works fine from the switch.
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Lower glove box??? That's a new one on me, I haven,t found that one yet. Share the secret please |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
the 2006 my's onwards have a top and bottom glovebox...the top one houses the cd changer and has a very small space to the right of it.. ... - .- -.
Thanks Stan, too many little hideaways are a waste of space, my 2004 is as flash as I will probably get so I will avoid a lot of thee problems I see other forums. Still lovely Lady though. |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
I have to hit the lower glove box anywhere from 1-5 times for it to release. Top one releases first push. One of those quirks...I'm sure it can be fixed but haven't messed with it. Not sure if the issue is with the button or the release mechanism inside the glove box. 2014 FF Autobiography 5.0 SC
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
My small space is full of 'venture cam' Have same issue with lower box going to have a look tomorrow. |
glad I'm not the only one. It may well be the weight of the glovebox putting pressure on the lock mechanism. Regards
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
You have to tap it in ?
Hi all
Can you lift up and out (by the hinge) on the glove box like most other makes to remove it and see if anything is jammed in behind? 2014 FF Autobiography 5.0 SC
~Don't think its that easy to remove.
Had a closer look at glove box as needed to get to fuse box. There is a retaining clip on the side of the glove box (nearest centre console) that you just have to squeeze gently (towards the box) and the box will lower giving access behind. |
thought so....most do that. I haven't had a chance to dig behind mine but will try this weekend. 2014 FF Autobiography 5.0 SC
