Home > Technical (L322) > Upper Tailgate Glass to lower Metal panel fixing
mike whiskey
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
How does the upper tailgate glass fix to the panel at the bottom of the uppor tailgate?
I ask because mine seems to be loose at one end, and when it has been raining opening the tailgate results in a significant amount of water pouting out of the tailgate. fortunately into the door shut rather than the boot, but still, its something I would like to address.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2, FFRR. D3, Freelander 2 and now back in FFRR.
Yes I'm a masochist....
Post #365687 6th Jan 2016 6:03pm
Zirconblue
its bonded on the same as windcreens.
The upper tail gate has a complete frame which the glass is stuck to. Unlike say a Citroen AX where the glass forms the structure
Post #365698 6th Jan 2016 6:28pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
It's bonded on like the front screen .
The front has a rubber pieces at the top (sides and bottom covered by removable plastic pieces)
And the rear screen has a rubber at the bottom .
If it's the rubber pieces you're talking about I can get you part numbers later as I just replaced all mine on Monday .
If it's the glass leaking you're talking about , to check for leaking screens get a nearly empty fairy liquid squeeze bottle and mix around 50-50 with water .
Squeeze the liquid all around the screen while an assistant inside squirts all around the inside with a can of dust-buster if you don't have a compressor .
Obviously a compressor hose is better !!!
If you see bubbles appearing , you found your leak Laughing
Post #365704 6th Jan 2016 7:06pm
