Home > Maintenance & Mods (L322) > Rear Wiper Issue
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Rear Wiper Issue
I've searched high and low both with search and wiki and failed so........
All works just fine but I have a dribble coming from down around the camera, on the outside. At first I thought it was water from the roof but as so regular I'm starting to think I have a leak as ever time I go out I get this mess.
The wiper motor is only 5 months old so don't suspect that item but possibly fitted poorly ?
Has anybody experience of similar ? Many thanks
Paul
Post #365695 6th Jan 2016 6:25pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
It's easy enough to take the rear spoiler off to see .
Top section pulls off on inside of tailgate and you'll see 3 bolts(maybe4) holding spoiler on .
There's also a plug for 3rd brake light .
Post #365730 6th Jan 2016 8:46pm
Pvw10
Good shout, I will do that.
Hopefully it's a loose water pipe after the new motor was fitted. I will check and report back here so others may benefit. Many thanks
Paul
Post #365731 6th Jan 2016 8:50pm
if its outside it won't be the washer feed, these are internal and run inside the upper tailgate trim, and from memory come in from the opposite side to the camera in any case :thumbs:
the wiper motor is also in there too, and if that leaking it tends to pool in the trim panel and drip onto the rear parcel shelf Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #365738 6th Jan 2016 9:17pm
Pvw10
So based upon the fact all the inside is dry then it's probably where the pipe comes from inside to the outside and connects to the wiper wash bit, makes sense. Many thanks
Paul
Post #365739 6th Jan 2016 9:20pm
there isn't a pipe for the wash wipe as such, it basically connects to the wiper motor (to the nozzle on the back red circle) and is fed to the outside through the spindle of the wiper arm (blue circle), the nozzle of the washer is basically in the wiper arm itself.
Last edited by northernmonkeyjones on 6th Jan 2016 9:33pm. Edited 2 times in total
Post #365742 6th Jan 2016 9:23pm
Pvw10
That's it burst my bubble thought it was sussed then Big Cry
Oh well I will lift the spoiler and see what I can. Many thanks
Paul
Post #365744 6th Jan 2016 9:25pm
sounds like its just trapped water to me, the spoiler is easy to remove but can try your patience getting it back on.... there isn't anything much to see under there TBH. There is nothing that can't be fixed with a hammer😜😜
Post #365748 6th Jan 2016 9:35pm
Pvw10
On the searches I kept coming across mentioned trapped water but this seems just to much, almost constant at times but hard to tell.
I wonder if any others reading this can say if trapped water comes out around both sides of the camera, guess that would answer it as little point in pulling the spoiler now. Many thanks
Paul
Post #365751 6th Jan 2016 10:02pm
rangie47
mine does it, its just standing water.
on another note my motor has started to leak, but the motor works fine,
im thinking is the an area on the upper tailgate by the motor under the spoiler thin enough to drill a hole ,fit a normal jet and do away with this silly design .
Has anybody done this mod ? 2007 tdv8 se ,stornaway grey
Post #365767 6th Jan 2016 11:01pm
no but there is a fairly easy fix for the existing setup. It will be the seal against the shaft in the motor, can be removed and replaced with a new seal, just requires a bit of fiddling about. Have a search for rear wash wipe fix, there is a full description of how to do it Thumbs Up
http://www.fullfatrr.com/forum/topic9924.html found it.... There is nothing that can't be fixed with a hammer😜😜
Post #365780 7th Jan 2016 12:19am
rangie47
Yes I've read that thread .seems to be hit and miss wether it's successful.
I'm just thinking of bypassing it if I can Thumbs Up 2007 tdv8 se ,stornaway grey
Post #365820 7th Jan 2016 10:12am
mpirie
Replacing the seal worked for me. Thumbs Up
It was a bit of a faff, but way cheaper than replacing the motor and gearbox.
Mike
Post #365826 7th Jan 2016 10:55am
miggit
The wiper repair is quite easy to do, when I did mine I found that the old seal can be poped out of the black plastic fitting with a screwdriver, making refitting a lot easier. And I did have to repair the pitted shaft with some epoxy resin to stop it ripping the new seal. I also used the epoxy to stick the plastic fitting back in place rather than small screws. As long as you don't push the new seal all the way home, and just leave it flush with the plastic bit, the seal will be running on new(ish) metal. The only other thing I did was lube up the shaft before reassembly and used a twisting motion, otherwise the spring can become dislodged from the seal Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #365883 7th Jan 2016 5:52pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
I spent some of the weekend Censored about with my rear wash-wipe but I just cannot get it to work. I replace the non return valve, and that is working fine as evidenced by disconnecting the delivery side and pushing the wash wipe stalk - a good squirt comes through immediately.
Anyway, so with it all connected up, the pitch of the motor changes from normal to a high pitch when the pipework is reconnected and the switch is pressed - suggesting the pump is trying to work against a backpressure. So, that suggets blocked nozzles. After running a sewing pin in and out of each of the 2 nozzles, I was rewarded with a small squirt of very brown water - suggesting that the blockage has just been cleared, no? Well, nope - upon trying again, I got a few ml of brown dribble before normal non-service was resumed. I tried the "poke pin through it, then hit wash button" technique 5 times but still to no avail. I can only therefor assume that something inside the body of the wiper motor assembly is causing the blockage? Should I try putting some suction on the supply hose into the body, to try and draw a blockage back out? It really is beginning to irritate me now! NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #369315 29th Jan 2016 12:13pm
