Home > Maintenance & Mods (L322) > Security - OBD Lock fitted
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
When even newer to the forum than I am now, I searched for information and posed a question about securing the OBD from tampering/access.
Today, I had such a device fitted by a local company with whom I have no connection beyond being a retail customer.
The best way to describe the device itself is as a shoe box type construction where the OBD is inside the base and the lid goes on top but with sides that are the same depth as the lower box sides, if that makes sense. The bottom box holding the OBD is part of a mounting frame and the lid is locked on, covering the box all the way to the frame so that even if the frame was removed, the OBD is still secured within a box.
EDIT
Following advice from another member - thank you, Craig, that was a good call - I have removed the photo and description of the OBD's new location. If a member is thinking of fitting this device, I can supply details of the company I used, photo and fuller description via pm.
Post #365746 6th Jan 2016 9:26pm
Giantlandyman
Bump.
Again, thank you, Craig.
Post #365773 6th Jan 2016 11:31pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Having my roots in Mechanical R & D I think its a brilliant idea. In this world of high tech comms / cloaning / ease of access / etc criminals are moving upmarket and getting equiped with very very smart softwear / hardwear to bypass security systems fitted to up market cars. In the end though, I guess nothing can defend against a low loader and a powerful winch.
I am currently working on developing a mechanical means of locking my handbrake / autobox selector, but am still at the head scratching phase.
Peter
Post #365774 6th Jan 2016 11:33pm
Giantlandyman
Looking forward to seeing what you come up with.
I too like simple, effective but elegant engineering solutions over complicated electronic devices.
Post #365776 6th Jan 2016 11:42pm
Strider
You have pm
Post #365779 7th Jan 2016 12:02am
Lost for Words
Unfortunately, the OBD port is just one part of the CANBUS and an alternative place could easily be used instead, and will be if everyone starts to protect their OBD ports... Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #365833 7th Jan 2016 11:58am
Giantlandyman
That's very negative, if you don't mind me saying.
Are you saying it isn't worth the effort now because as the idea catches on, miscreants will find another way to access the electrics in the future?
Without giving specifics, can you define "easily", please?
Post #365836 7th Jan 2016 12:10pm
Lost for Words
Sorry, I didn't mean to be negative about it as such, it's just far from bullet proof.
Moreorless, yes, that's kind of what I'm saying. Struggling to define easily without giving direct pointers, though I'm sure many of them, and the manufacturers of such devices that they use, are already aware of how. Will drop you a PM.
Thumbs Up Visiting from DISCO3.CO.UK
Post #365837 7th Jan 2016 12:27pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Its and interesting subject but I can't help thinking there must be a simpler even DIY way of disabling the FF. I'm no expert on vehicle electronics but I'm sure there are plenty of little cables, connectors etc which - if isolated by a small discreet rocker switch- will stop the car being started or opened.
I suspect a dummy OBD port fitting is not cheap and I also suspect Lost for Words will be proven right.
Anyone fitted a simple DIY solution?
(Cue pictures of big dogs in the boot) Whistle 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #365905 7th Jan 2016 7:31pm
Giantlandyman
I suspect you are correct regarding discrete switches etc.
However, fitting such could jeopardise the two year warranty in my case and that is not an option, hence why I haven't gone all out for a secondary immobiliser and alarm etc. Some sort of tracking device is on the research list at the moment, though.
Post #365956 7th Jan 2016 10:37pm
