![]() | Home > Maintenance & Mods (L322) > Replacing ignition switch on a 2008 tdv8 |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Have you definitely identified the ignition lock as the problem?
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Pretty sure , put key in steering lock clicks off as it should then turn key to position one and no lights or any response on dash and car won't start , turn back to position 0 and then back to position 1 several times quite vigorously or wiggle the key up and down a few times and dash lights up and car will start , doesn't do it every time you start car maybe once out of 10 times , for me wiggling the key is the main indicator that the ignition switch has a dodgy contact! |
