![]() | Home > Technical (L322) > if anyone has the time can they offer advice? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
Does the low range physically work as it should without errors appearing when you select it each time?
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
Could just be as simple as a sezied transfer motor, not unknown if cycled to keep moving |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Or if there is a fault perhaps someone disconnected the low range switch hence it doing nothing.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
Have you tried getting the codes cleared and the checking a day later to see if they have returned?
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 ![]() ![]() ![]() |
Mpirie
