Home > Maintenance & Mods (L322) > Changed FSR - 2 bits left over???
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Finally got round to changing the failed FSR today, and as soon as I removed the black trim from under the pedals area (the bit with the small footwell light in it), 2 bits dropped out. 1 was a cream plastic piece, half circle shaped (imagine cutting a toilet roll centre from one end to the other), and the other part was a threaded bit of stud, about 6" long? Couldnt see where they were from, any ideas guys?
Also, as soon as I removed the under trim, a small motor type thing hung down by some wires, so Ive just tucked it back under there once I put it all back together. The plastic bit I mentioned earlier looked as though it could of fitted around the motor
Any ideas people?
Post #365889 7th Jan 2016 6:50pm
have a look at these three how to's and you might be able to see the bits that you have described,
http://www.rswsolutions.com/index.php?opti...;Itemid=73
http://metricrat.co.uk/replacing-the-final...kiii-2002/
http://www.fullfatrr.com/forum/topic781.ht...eplacement ... - .- -.
Post #365891 7th Jan 2016 6:58pm
Weegie
Presumably your reach and tilt motors for the steering wheel don't work? John
GAP iiD BT-Sold
Post #365892 7th Jan 2016 6:59pm
mrblonde
Hi guys
Stan - neither of my spare parts are on any of those how to guides Im afraid, the bits seemed to come from up under the steering wheel area?
Weegie - I'll be honest my friend, I have no idea as never use any of those adjustments for the steering wheel, I''ll try it first thing in the morning when the boss (mrs) is back
Post #365897 7th Jan 2016 7:05pm
Weegie
It's just that your description of the "half toilet roll" sounds like the plastic bit on the reach motor which is prone to failure. John
GAP iiD BT-Sold
Post #365899 7th Jan 2016 7:07pm
mrblonde
This is the part, and other than the lift/tilt not working, is it a problem not getting it fixed just yet?
Post #365904 7th Jan 2016 7:27pm
Weegie
That's the part. http://www.fullfatrr.com/forum/topic4144.h...or+plastic third post
It is pretty common and, provided the wheel isn't flopping about, many live with it. My tilt motor isn't working so I've just got it to the position that suits and left it. Might get round to fitting another motor if I can get one cheap enough. John
GAP iiD BT-Sold
Post #365908 7th Jan 2016 7:42pm
mrblonde
Yes, and the bit of stud I have is the part going into the reach motor too. Steering position is fine, and doesnt move so I'll live with it for now. Do you know if its an easy fix, or a pain in the @ss?
Forgot to add, my steering column has made a clicking sound for a year or so now when driving slowly around car parks etc, when its on almost full lock, could this be something to do with it?
Thanks again
Post #365912 7th Jan 2016 7:44pm
Weegie
If you do a search there are some threads on the subject. Not sure whether there's a work round or not. John
GAP iiD BT-Sold
Post #365913 7th Jan 2016 7:48pm
