Home > Technical (L322) > Nice start to New Year, L322 TDV8 Turbo Failure
Robgosty
As above, done literally less than 800yds from front door, booted it a bit to catch lights, whoosh no power, Censored thought I, turbo hose gone, limped home at tickover, just turned into my close, bong, oil level warning, oops i thought, not looking good, big pool of oil under car, Blue Flag recovery to pals workshop, turns out turbo gone, sucked all oil into airbox (and intercooler), dropped all oil from intercooler and airbox, looking at a minimum of 2 X turbos, 2 X EGR valves, poss intercooler and a bucket of labour happy days Big Cry
Had car approx 12 month, 107k, FSH, just had service & gearbox flush, prior to it letting go no whistling or weird noises, not a happy bunny, keeping car so seems common sense to replace both turbos and EGR valves just to be on safe side, hoping no engine damage Sad joys of R/Rover ownership, just fitted FFRR sticker so wondering if this was cause of problem Whistle Whistle Whistle
Post #365843 7th Jan 2016 1:15pm
depends where you put the sticker Rob...
seriously though its pants that this has happened...hope you get it sorted soon.. ... - .- -.
Post #365844 7th Jan 2016 1:18pm
Robgosty
Hi Stan, did not realise sticker placement was so critical, there were no instructions, Rolling with laughter Rolling with laughter
Post #365854 7th Jan 2016 1:56pm
Laughing ... - .- -.
Post #365855 7th Jan 2016 2:00pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Sorry to read that story. If its not a rude question - whats the cost likely to be? Whistle 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #365900 7th Jan 2016 7:19pm
Ouch - I feel for you
Post #365906 7th Jan 2016 7:32pm
Robgosty
Guesstimate about 3k to 4K, :blub:however could be worse if turbo had hydro locked engine or simply disintegrated would be really bad, only one complete s/h engine on bay of e at £4550 and 71k miles Shocked God only knows how much a recon would be with turbos EGRs etc on top, kak happens just got to bite the bullet an move on Wink
Post #365923 7th Jan 2016 8:17pm
Rosco
Sorry to hear Rob, get the Man Maths on it, wont feel so bad, all the best Thumbs Up
Post #365924 7th Jan 2016 8:24pm
what a PITA, hope the garage can sort it easily enough. It may sound an expensive bag of parts, but once it is done its one less thing to worry/think about! Thumbs Up
Heres hoping that the engine has suffered no internal damage, if they are having the turbos off get them to check the oil feed pipes from the sump to the turbos, these can block and cause oil starvation in the turbo units themselves. and as its probably got no oil in it it may be worth having the sump off as well. There are 2 drain plugs for the oil, if the car hasn't been serviced properly and the tec was lazy they may have only drained one part of the sump, the one which gets left is the one where the oil feeds to the turbo pick up and if it hasn't been drained there maybe a bit of crud in this section..... There is nothing that can't be fixed with a hammer😜😜
Post #365925 7th Jan 2016 8:32pm
Robgosty
They have had engine running so luckily no damage, at least when it's all done should be good for 100k trouble free (maybe) I blame that sodding FFRR sticker I put on Whistle
Post #365940 7th Jan 2016 10:03pm
