OK - I am sure you have all heard this story before but I am looking for advice on what to try next on my FBH.....
I have a Webasto FBH fitted to a 56 plate TDV8 which has only recently stopped working - it worked on timed start perfectly well last autumn but has since stopped. When the weather is cold, it will attempt to start every time but after several timed runs, it always shuts down at 4m 05s to 4m 07s. According to one of FrenchMike's posts on the 75 & ZT forum (excellent source), this points to a glow plug problem.
Yesterday, I stripped the unit and cleaned it and there was a lot of carbon build up but on re-assembly, and testing on the car, I get the same symptoms.
While apart, I've tested the resistance of the (cold) glow plug using a potential divider as 0.365ohms which seems to be at the to end of the range quoted for the correct resistance. When heated to something less than red hot in a flame, this rises to about 1.2ohms. All this suggests to me the glow plug is OK based on what I have read.
I've removed the gunk from all the resistors on the PCB and these seem to measure correctly.
I tried disconnecting the fuel supply during the early part of the firing sequence in there was never any fuel delivery but when I tested the fuel supply by pulsing the supply to the pump with a false feed, there was a healthy fuel delivery.
Any suggestions of what to try next? Send the PCB to FrenchMike or try a new glow plug first? Or any other good suggestions?
