![]() | Home > Technical (L322) > Fuel Burning Heater Fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
is the battery ok...might be worth drop testing it to see if it still holds charge.. ... - .- -.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
EU 29 Member Since: 29 Oct 2014 Location: London Posts: 9 ![]() ![]() ![]() |
Did you find out what was wrong? My 57 FFRR TDV8 has precisely the same problem. Unit fine when engine on though, I can feel the hot air pumping out from the small FBH exhaust by the front wheel. |
5c0tty Member Since: 07 Sep 2015 Location: Long Buckby Posts: 26 ![]() ![]() ![]() |
I'm having the same issue too, just cuts out when using the remote or timer, seems to run ok with engine running but i can be sure |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Gents, check out ,My post FBH Success at last for Ian at Sub Zero |
Hi j evro
@Scotty
