Home > Maintenance & Mods (L322) > ENGINE OIL RENEW & TRANSFER BOX OIL
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi
Another service day on one of the FFRR - Thought I would post some useful pictures in case you are:
Changing Engine Oil or Transfer Box Oil
Transfer Box Fill & Drain Plugs pictured below:
NOTE: I Always use on the thread PTFE Plumbers Tape to ensure 100% seal (not too much just 3 clean winds on threads) - REMEMBER use a Torque wrench - Thread Size 16mm = 22Nm or 18mm Thread plug = 28Nm ( Measure You Plugs !!!!!! )
and don't forget fill on level ground and fill till it comes out of filler hole !
KEEP LOADS OF THESE COPPER WASHERS IN YOUR TOOL TRAY - YOU NEED TO USE NEW ONES ALL THE TIME
in case your wondering I change the Transfer oil every 10K - Its thats easy & worth piece of mind
Piece of Kit so useful when changing engine oil.
NOTE: 18 litre version is a must as the FFRR holds 9.5 litres
also note: What comes out - goes in - MEASURE what you take out in measure jar ( then you can't overfill her Thumbs Up
Unit comes with 3 clear tubes as pictured above
1 x tube is an exact fit onto the FFRR Oil Pipe as pictured - just attach - take off the Main Oil Filler cap & suck the oil out - that easy :thumbs:
This is the part in case you want to order one ( I always keep stock in at home - saves time & fuel when working on them - never with parts )
part laid out so you can see - Its 1 complete unit and a Censored to change if you need to
Again - I hope this all helps someone
Keep things coming in - Knowledge is key to everything we do on here Thumbs Up
Post #366244 9th Jan 2016 8:00pm
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Good post.
I've just returned from a 3 week holiday in Perth. Emirates all the way. Great airline. 😊
Post #366620 12th Jan 2016 6:07am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Useful info sir. If i remember correctly you posted about changing the engine oil before but I cant find your thread.
Do you have a link?
I assume the oil change drain is all from the top.
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #366918 13th Jan 2016 8:54pm
Yes Ajac the 4.4 TDV8 get drained from the black tube (as seen above) along side the filler cap...
Just to make it clear, the clear drain tube from the engine oil suction machine only needs to fit just inside the black rubber tube end... NOT all the way down the tube to the sump!
We get asked this often!!! Bow down
Post #366966 13th Jan 2016 11:16pm
