Home > Technical (L322) > 24 hours later with my first L322
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
So picked her up , and I have to say its the nocest car Ive ever driven , absolutely love it and wouldnt trade it for anything , but this is where the fun of second hand cars start, a few little issues :
1. It has the retractable side steps, passanger one works perfectly but the drivers side neither fully retracts or deploys, it kind of cycles a bit and goes mostly back but not the full way, how does one fix this ?
2. The passenger side xenon has a habbit of turning off sometimes , if i flick the lights off and on again its fine but id like to get that one fully sorted.
3. The smart key battery is low on the second key, what battery is it and can I replace it myself ?
Post #366333 10th Jan 2016 10:55am
steadyaway
Looks smart. Enjoy. 👍
Post #366342 10th Jan 2016 11:48am
Eric Cartman
Also does anyone know how to change the dials to km/h ?
Post #366346 10th Jan 2016 12:38pm
its a setting in the menu..must be documented in the owners manual... ... - .- -.
Post #366347 10th Jan 2016 12:42pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Re: 24 hours later with my first L322
[quote=
[/quote]
Ours has the same problem. I read on here that it may be the ballast resistor that screws onto the back of the headlamp unit.
Post #366352 10th Jan 2016 1:40pm
Eric Cartman
Does yours throw any errors when it goes ? Nothing comes up on the dash for mine which is annoying to say the least, the bulb is a different colour to the right side so im going to check if its a cheap / old bulb first
Post #366356 10th Jan 2016 2:12pm
The smart key batteries are easy to change
1. place the key on the table face up keyring end closest to you, look at the opposite end to where the keyring is.
2. between the 2 metal parts is a small black rectangle.
3. push this in.
4. as pushing in open the metal part on the left as looking at the key, hinges round the key ring end
5.under the cover you will see a clip and a flat black bit, this is the battery drawer.
6. pull out drawer
7. remove battery. CR2032.
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #366357 10th Jan 2016 2:21pm
PaulTyrer
None at all! Turn on the lights, passenger side light off, turn switch on and off a couple of times, light comes on. These are both new xenon bulbs. I have a spare resistor which I'm going to swap when I get chance, but the screws are difficult to get at!
Post #366359 10th Jan 2016 2:26pm
Im not sure you can completely change the speedo to read Kmh, you can however get a little box in the centre of the speedo to read in Kmh:
on the dash menu, select trip computer - units - Kmh, l/100km this will then put up a digital speedo with the units in Kmh.
I'm not sure if you can change the whole speedo on the iid. but someone will know.....
In regards the steps, it is probably catching/jamming/stiff, a good clean and a squirt of lube may help? There is nothing that can't be fixed with a hammer😜😜
Post #366361 10th Jan 2016 2:30pm
Eric Cartman
Id find it very hard to believe the speedo can't be km/h , its a screen , I would have thought it would just be in settings but now I'm starting to think it may be a ccf edit or at worst a reflash.
Post #366374 10th Jan 2016 4:27pm
its probably a CCF edit, but its not something you can just do on the dash Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #366379 10th Jan 2016 4:46pm
Eric Cartman
anyone know if an iidtool can change it ? I was probably going to get one anyway but If I need it for this it makes it more urgent.
Post #366408 10th Jan 2016 7:00pm
i think it can,
Post #366410 10th Jan 2016 7:08pm
Eric Cartman
grand, anyone got any way of getting a discounted BT iid tool ? Laughing
or is there anyone in the leinster region of Ireland with a non vin locked tool who wants to help me out.
Post #366415 10th Jan 2016 7:28pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
The iid defo can change the dials the kph. Not just the little box but the numbers around the dial. There's plenty other reasons to buy one Thumbs Up
Post #366434 10th Jan 2016 10:55pm
