Home > Maintenance & Mods (L322) > Engine Flush Additive?
Use Engine Flush Product?
Yes, every time
20%
 20%  [2]
No , don't touch with a barge pole
80%
 80%  [8]
Total Votes: 10
Thinking of bunging some of this (for example) into the engine next time it is ready for an oil change.
TD6 Engine (running as good as ever) now at 165K miles
I had read that using on high mileage engines can cause problem with the oil pump or cause oil leaks, whilst other have had only success with it.
What does everyone think? .
Post #366446 11th Jan 2016 12:33am
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Not sure about this product "harmful engine deposits" If you know the history of your FF and its service intervals that have been applied I dont think this product will do much for you.
Releasing a pile of "harmful deposits" all in one go may be a bad idea.
Piston rings are most likely the target here.
If you are changing the oil prior to recommendations and you use a quality oil your engine is going to be relatively deposit free.
You say your engine is running fine......save your money for an oil/filter change.
Post #366454 11th Jan 2016 2:34am
dingg1
IF the engines has had regular oil changes with fully synthetic I think you'd be wasting your time and money using it
Post #366461 11th Jan 2016 6:08am
Zirconblue
If quality oil has been used and changed regularly then you shouldn't need it, as most quality oil has detergent in it anyway.
If the engine has has a sporadic service regime or had rubbish oil used then In theory it should break up any sludge and it'll drain out with the oil.
I've used it on other cars in the past when i've serviced them just after buying them and it's not caused me any problems.
But there is the possibility it'll clear out gunk that was helping to seal a gasket, when the gunk is cleared away the gasket starts weeping but it's unlikely to cause massive oil leaks, as if the gasket was that bad it would be leaking anyway.
In theory it can help with hydraulic tappets, chain tensioners and vanos, by loosening any deposits that might be blocking oil ways. The trouble is it could equally loosen off deposits from elsewhere and they then get circulated into said oil ways making things worse.
Post #366465 11th Jan 2016 6:53am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Joe,
As some others have said don't do it!!!
I had a V8 Disco2 last, 6 months after I bought it I did a service and used a 'cleaner'. When I drained the oil I noticed a lot of stingey goo/deposits coming out with the oil. (I gave the engine another flush with new oil as well).
2 months later on the motorway lots of knocking from the engine. Recovered to and independant who removed the sump and found the oil strainer blocked (and sump) full of the goo .
So that was a reground crank, new shells etc...
Cheers
Simon
edit also Censored up the hydraulic tappets!
Post #366477 11th Jan 2016 10:34am
I would never use a flushing agent. Better to drain the oil immediately after turning the engine off following a long journey when it's really hot. Leave it draining overnight and refill with fresh oil next day. Amazing how much oil drips out overnight if you are on a level surface
Post #366480 11th Jan 2016 11:00am
CS
Anyone with a LR warranty should bear in mind that the warranty handbook says that using non-LR specified additives invalidates the warranty. Only Range Rovers since 1988
Post #366569 11th Jan 2016 7:27pm
Zirconblue
and changing the oil and filter more often for a few oil changes should flush out any gunge, using a decent budget brand oil of the right spec will do it (ie. not Mobil branded but Comma etc) it should clean it out in a more measured manner rather than letting all of the stuff go at once. But if the engine has been used with decent oil and had regular changes in the past then even that isn't needed.
Post #366574 11th Jan 2016 7:52pm
So I could find some cheap stuff of the right spec (if that is possible - I have never found any cheap fully synthetic 5W-30) and use that to "flush" with instead? No chance of using any old cheap oil to flush, even if only running the engine at idle? .
Post #366604 11th Jan 2016 11:02pm
Zirconblue
It depends how long you want to leave it in there. Really cheap stuff you'd want to drain after an hour or two, you can buy actual flushing oil for just the purpose.
What i meant by cheap fully synthetic is buy some Halfords own brand or similar (because it's still a lot cheaper than say Mobil 1 etc), you could leave it in for a few months and change it.
Post #366607 11th Jan 2016 11:24pm
steptoe
If you want to flush the engine before an oil change the best and cheapest fluid to use is ATF (automatic transmission fluid).
Add a litre or two of the cheapest you can find, run the engine for 15-20 minutes then drain.
Post #366674 12th Jan 2016 3:04pm
johnboyairey
RP123 wrote:
Joe,
Cheers
Simon
To be fair, the old rover v8 engine you are referring to, is prehistoric in it's design, using mineral oil, and has a well known history of 'Black Death' build ups, and thus, using a flushing product, will send hunks of goo around, but remember, it was there already! It was waiting to die prematurely.
I say this, as I had exactly the same issue with my old p38 Rangie. The day I bought it, I drove it home, and at a set of lights, I heard the tappetts clattering, I switched off, and after a look round and oil checked etc, restarted, and drove it home. I took off the rocker covers, and there was the most hideous coating of Black Death, dried oil, and carbon, all waiting to give the strainer a coranary! (The strainer ,is the oil pick up,tube in the sump. It has a mesh screen to block the odd shard, and foreign matter)
I had to clean the rocker and head valley area, all with toothbrushes, then blast it with brake cleaner, reassemble rockers, that had all now gone south, so then dropped the sump. That had a carpet of death too. It would never have run out during an oil change..And the strainer was on deaths door. That was cleaned, and I replaced the big end bearings in situ. I filled with oil, and changed again after 100 miles. The car was quiet, clean, and apart from the usual long list of other p38 woes, was a good engine, and went a further 20k, till I sold it.
I think that with modern engines, you will hardly see anything like the Black Death from those older generations.
I have not used it on my l322 v8, as it is still so clean already! However, I have throw in a tin on engine stop leak ffrrom Wynns, and have had no issues. But leak did almost dry up!
Obviously use it as per the instructions.
On my previous LR, I had cause to remove the sump on my disco 2 td5, to change the much discussed oil pump bolt, that goes loose, and leads to engine failure. I expected a sort of decent carpet of sediment, however, it was hardly showing any. Just needed a rinse out with no scrubbing. And it was not already modified. So it was mileage correct at 110k. This is no doubt because of its twin oil filters, one being a centrifruge. So peeping under the rocker cover, showed modern clean engine internals.
The old rover v8 engine, has served many generations, from the mid 1960's! However, finer engine tolerances, and oil development, has given us better reliability.
Post #366785 13th Jan 2016 1:17am
johnboyairey
RP123 wrote:
Joe,
Cheers
Simon
Post #366786 13th Jan 2016 1:18am
johnboyairey
RP123 wrote:
Joe,
Cheers
Simon
Post #366787 13th Jan 2016 1:19am
