Home > Maintenance & Mods (L322) > Adjustable Tow Bar ? |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Yup: VUB000720 Visiting from DISCO3.CO.UK
12th Jan 2016 2:25pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3204 |
Also known as a "Farmers Hitch". They sometimes come up for sale on the forum. John
12th Jan 2016 2:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8483 |
I have noticed the same, it is slightly low for a trailer to sit totally level, but said the adjustable farmers hitch will sort it. It fits into the armature in place of the detachable receiver so you don't need to change the whole caboodle just remove the pun and knock out the detachable receiver and put the farmers in its place. It is also a removable part too with a pin and clip to retain it. There is nothing that can't be fixed with a hammer😜😜
12th Jan 2016 2:35pm |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 |
12th Jan 2016 2:47pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
How low is the trailer though? Trailers are supposed to have a slightly nose down attitude, it helps stability when towing. (according the Ifor Williams' guide to towing)
12th Jan 2016 3:15pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
I bought mine from PF Jones via ebay. It came with a towing ball fitted to the towing plate, a carry case for it, a 7 pin prewired socket and mounting plate (XPF027B2M).
12th Jan 2016 3:36pm |
FullFatDunc Member Since: 16 Aug 2015 Location: South Somerset Posts: 65 |
Thanks everyone
12th Jan 2016 3:44pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7814 |
There are actually 3 different versions of the farmers hitch - I've had 2 of them - due to me leaving one in my shed in France and coming home without it
12th Jan 2016 7:58pm |
What was the socket for? That should already be attached to your main towing armature under the car.
The PF jones one i linked to is the one with the pin, rather than a bolt. incidentally the middle hole on the hitch is the standard height (which all modern trailers are built to), it's about the same as the quick release ball height. |
12th Jan 2016 8:26pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Got one from Gumtree, unused £40. |
12th Jan 2016 9:29pm |
If you're removing it when not in use, then I also recommend a KYB000011 plug for the square armature - available from Dan |
12th Jan 2016 9:40pm |
Zirconblue
12th Jan 2016 11:27pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The ffrr hitch is too low full stop, and there is no height difference between the swan neck and the 'Multi hole' farmers hitch in height. For some inexplicable reason the the adjustable hitch goes down rather than up I had to resort to a ladder hitch to get the correct height to comply with EU height regulations, it's supposed to sit at 18", the multi hole on the top setting was just over 16", how L/R get away with this is beyond me..... and then I thought that I'd put the hitch on upside down...... but it's too bloody short and fouls the bumper
13th Jan 2016 12:38am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I had one of those, took me all day to get it off. Had to use a bottle jack! Against the armature, so yes, put a bit of grease on it. I thought latter if I drilled the shaft, , it could go in upside down. I got myself a swan neck, and now I don't plough the car parks or soft grass verges. As I've said before, you can buy 50mm box section 5mm thick, and make your own, via eBay... (with the help of an arc welder). |
13th Jan 2016 1:42am |
