Home > Technical (L322) > transmission oil/filter change
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Guys is this http://www.paddockspares.com/auto-transmission-service-kit-1.html the correct kit for a 03 Vogue transmission oil/filter change. Probably won't buy Britpart but just want to confirm correct parts plus oil of course.
Thanks
Declan
Post #366616 12th Jan 2016 12:57am
Declan303
Nobody any idea Question no!
Post #366854 13th Jan 2016 4:05pm
what do paddocks say? ... - .- -.
Post #366859 13th Jan 2016 4:13pm
Zirconblue
that's correct for the Petrol ones yes.
I bought the britpart kit, it came with an pattern filter and a genuine gasket and o-ring.
To be honest the filter is a fairly basic affair and i doubt the 'genuine' one is substantially better.
you'll also need a T27 torx bit to remove the sump pan.
Post #366860 13th Jan 2016 4:16pm
johnboyairey
Yes that does appear to be correct. For the early v8. And at a cheap price too. Just make sure you are using the correct lt71141 fluid, and not equivilent. It's about £11 a litre, and only badged as Mobil. Get it online. P.s. It's honey/yellow coloured.
Post #366870 13th Jan 2016 5:28pm
I bought mine from forum sponsors AF Advanced Factors. Got everything I needed by searching through to my model type on their web site. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #366871 13th Jan 2016 5:38pm
Declan303
Cheers guys thanks for replies.
Declan
Post #366872 13th Jan 2016 5:47pm
Zirconblue
It's also badged as Esso too, Esso is the same company as Mobil.
Post #366879 13th Jan 2016 6:09pm
acrr1
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
The auto box is one area where it doesn't pay to use pattern parts - try Dan at Duckworths, he was very helpful when I did mine.
Post #366882 13th Jan 2016 6:20pm
Zirconblue
normally i'd agree but the filter is a VERY basic item, it's nothing special.
Post #366887 13th Jan 2016 6:35pm
Declan303
I had a quick look underneath today and could not see the filler plug on the gearbox. Any idea where its located, left, right, front back etc. There is a plug just to the front of the sump pan but somehow I don't think that is it.
Declan
Post #368342 21st Jan 2016 8:42pm
RRPhil
It’s on the right-hand side of the casing near the back of the transmission
Only use a genuine Filtran filter in your 5HP24
Phil
Post #368363 21st Jan 2016 10:12pm
Declan303
Thanks Phil Thumbs Up
Post #368364 21st Jan 2016 10:23pm
Declan303
Might be a daft question but anyway here goes. When I was changing the gearbox oil and filter the other day, I was wondering if there is any way to get extra oil out rather than just what drains from the sump. Would giving it a dig of the starter push more back into the sump or would that be a mad thing to do and possibly cause damage.
A mechanic I was talking to had a way in which he disconnected the oil cooler and connected up a pressurized can of atf and allowed the other side to bleed out as he pumped in the new oil. Think engine may be running during that process. Had a look and the oil cooler is buried down at bottom of radiator so decided was worth the bother looking into that. Think the diesels may have the oil cooler more accessible.
Post #370574 4th Feb 2016 8:24pm
RRPhil
The torque converter and valve body do retain a lot of fluid. Personally I’m a fan of just doing a drain and refill as it refreshes only just over half of the fluid and so reduces the risk of ‘detergent shock’ (i.e. the fresh fluid cleaning out all the gunk that has settled in the nooks and crannies) and also upsetting the controller’s adaptions through changing the clutch-pack friction characteristics.
Phil
Post #370700 5th Feb 2016 12:52pm
