![]() | Home > Maintenance & Mods (L322) > Soaking wet N/S A Pillar... Where to start? |
betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68 ![]() ![]() ![]() |
Sun-roof drains and door rubbers. I use Google translate, Sorry for my bad English...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
If the drain in that corner is blocked, the water cannot escape so will overflow into the area above the A pillar trim...
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
Thanks guys, much appreciated. Not too bad with the toolkit, happy to have a go at simple things if it saves trips to the garage.
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
Slow down I think you would see if you were driving on high suspension setting
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Had the same leak and the car went mental for a few days, I think there's an ECU behind the glove box. There is also a fuse box.
Hi all,
Please do be careful not to ram wire/welding wire down the hole as you could spear through the side of the pipe...
Easiest way is compressed air.
Thanks all, your help has been much appreciated.
