![]() | Home > In Car Electronics (L322) > 2009-2012 4.4L L iPhone cable and iPhone 6 compatibility |
Slaav Member Since: 02 Mar 2014 Location: GLos Posts: 32 ![]() ![]() |
I'm an idiot - double post |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Tune 2 air solves all your problems |
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
I have a 2010 model Vogue that doesn't audio stream but does Bluetooth hands free calls.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2720 ![]() ![]() ![]() |
No doesn't interfere at all, calls automatically cut off audio, works very well, basically your phone will pair to the car & tune2air at the same time. The tune2air plugs directly into iPod cable in chubby box. Can take a few goes to get it to pair , but it's about the best option out there. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
Or just plug an old iPod into the connector with your favourite 20 albums on it. Had a tune 2 air and couldn't make it work. Might have another go, but tbh I listen to the wireless...... There is nothing that can't be fixed with a hammer😜😜
Thanks guys.
Not sure about the wma2000, think it's designed for iPod usb which the one in the ff isn't, which is why we have a separate iPod socket.
2000 model won't work, I bought one by mistake, there are a few 1000 on eBay and yep you'll need the lr iPod cable, plenty on eBay too. |
So like a numpty I appear to have bought a 2000 WMA thingy which I read above won't work?
If you bought the esynic that doesn't work either.
I've recently bought the curly LR ipod/ iPhone cubby cable (thanks Jayboy). I've also bought a Tune2Air WMA2000.
Wrong tune2air Ryan.
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
Im using the genuine LR cable with the apple 30 pin to lightning adapter. This configuration didnt charge the iphone in my 2010MY so I installed a scosche passport inline to allow charging ( you can get these 12 to 5 v charging adapters on ebay but the scosche one is the only one that passes enough power to actually charge the iphone |
Not a clue about that Mark/ the online sales stuff suggests it should be compatible |
