Home > General > Another parking sensor question.
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Since owning the car i've always just got a long beep and no parking sensors ( i have fr & RR. None work) . Now i know the front left parking sensor is not connected as when doing my 2010 conversion i accidently striped the wire of the connector but to close to re join ( need a plug with a lenght of wire if anyone got? can you buy these from RR?). Could of been like it before as very frail.
Would one parking sensor cause whole system not to work?
I have searched and it says to listen for clicks? I can hear no clicks on any? Is it the module if i can hear no clicks and is this easy cheap job if so??
Post #36748 18th Nov 2010 7:49pm
oodathort
Hi yes 1 dead sensor all system diabled
Post #36749 18th Nov 2010 7:51pm
Nickj
Thanks. Will have to somehow get another PS plug with some wire attached and try again.
Post #36751 18th Nov 2010 8:16pm
mzplcg
Why not just solder in a length of wire?? You still have the plug, right? Solder & heatshrink tubing would be the order of the day.
Post #36753 18th Nov 2010 8:27pm
Nickj
Where its broken off (the wire) at the plug end is virtually in line with the plastic. Nothing to solder to!! 2 wires ok but don't think i'd join the 3rd!
Post #36778 18th Nov 2010 9:57pm
