Home > Maintenance & Mods (L322) > Anyone able to mod suspension settings in Herts/Essex
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Following on from another users post wanting to lower the access height setting, does anyone know of somewhere in Herts/Essex who could lower just the access setting on my 03 TD6 to help get 2 elderly relatives in and out (1 is 79 the other 83 and about 5' tall)
Thanks guys
Post #367710 18th Jan 2016 9:43am
Would DCC be able to do it? They may have the capability?
Post #367711 18th Jan 2016 9:46am
mrblonde
Hi Craig
I messaged DCC but the guy there said he's sure the TD6 is at its lowest setting anyway in access mode? Just seen his reply but havent replied to him yet
Also, bit random, if the access height is lowered more so to allow access to the dragon-in-law, would it cause any more wear on the airbags if they're deflated more? (I'm assuming thats how it works?)
Post #368504 23rd Jan 2016 8:48am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I did this on my 54 plate a while back.
You can normally lower it a bit more but as you say, I noticed when I drove off it did take longer to automatically reach normal ride height and so the compressor was working longer/getting warmer.
I use a chap called Michael at Green Land Land Rover near Colchester (01621 890083) who would be able todo this for you. Ask for Michael and tell him that Ash suggested you to call. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #368508 23rd Jan 2016 9:23am
Trebaix
I had the same problem, elderly relative struggling to get in, so I carried a sturdy caravan step in the boot that they used as a step up. Check out awning-centre.co.uk for examples from £10 upwards.
Colin
Post #368543 23rd Jan 2016 1:26pm
