![]() | Home > Technical (L322) > gearbox overheating - amber message |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35736 ![]() ![]() |
it seems the problem comes up after a long journey, a short trip to the dealer should be ok if you take it easy.. ... - .- -.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
The problem is , your oil has allready overheated and will have lost some of its properties .
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Well decided to get LR assist out.
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
Hi.
£800 is right around where I was quoted from a dealer .
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8752 ![]() ![]() ![]() |
^the ZF fluid is specific to the gearbox and is expensive. Royal Purple ATF isn't the correct spec for the 8 sp ZF box, or the 6 Sp box either as far as i can tell, these need to have Lifeguard 6 or 8 respectively and i don't think that it comes up to the correct spec for the box.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1005 ![]() ![]() |
I think that’s the first time I’ve seen a problem posted regarding the 8HP70 transmission. How do they reckon that replacing the filter and fluid is going to cure a clutch overheating problem? (Your transmission has 5 clutches, by the way – not including the torque converter lock-up clutch). Surely the extended warranty covers an internal fault with the transmission?
The only ‘official’ alternative to Lifeguardfluid 8 is Petronas Tutela Transmission AS8
Thanks for the useful info chaps. |
Well , I would want to look at the filter once it's changed and analyze the oil when that's flushed .
The only way the filter could become clogged is if something in the transmission was generating debris – in which case there’s an internal fault with the transmission. Land Rover technicians don’t have a clue about the operation of the transmission as they’re only trained to replace them and not fix them. You might be better off speaking directly to ZF at Nottingham – I’m sure they would be mortified to hear that one of their flagship transmissions has failed after only 4 years.
I agree with Phil, there has to be something which has caused the overheat, not just a clogged filter, something has to have worn in the box to cause the debris to clog the filter in the first place
car has only done 43K miles |
