![]() | Home > Maintenance & Mods (L322) > Gap iid bluetooth |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Once you've selected what you want, make a final check of the battery voltage and select "Upload changes". You'll be asked to confirm and then the IID will proceed to write the CCF. Afterwards, cycle the ignition when the IID asks, it will clear any faults and you're all done. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Have been seriously thinking about purchasing said device, however one slip of the finger and all hell breaks loose, not sure now! |
It's only really the flashing (inc. CCF editing) that carries significant risk; the rest has little potential for problems. Aside from that, the tool has been made as user friendly as possible, is very safe and you get top service from GAP. |
Aye I suppose you're right, am getting |
That's the great thing; not only does it negate those £40 fees, it's also more convenient, being available for you to use whenever you like and you can save all the codes and data at the touch of a button. |
Do you work for GAP? |
Nope. I'm just a happy customer. |
Ah ok, thought you were giving me the pitch |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1861 ![]() ![]() |
Come up one night, and I'll let you have a go of mine |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8106 ![]() ![]() ![]() |
Depending on how far apart you are - it may be worth paying for an additional VIN licence on an existing tool rather than buying your own - and coming to some suitable arrangement on how to split the difference |
That's a generous offer Mikey, as I have a few fault codes, and you don't work for free, there would have to be a charge involved. |
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
For the record, there is always a risk when flashing the CCF or an ECU. However, we've incorporated several safety nets which prevents such occurrences. It's been more then a year since we had such a case which are generally caused by an issue present on the vehicle (bent, dirty OBDII terminals) or by user error (panic, tool disconnection during flashing). We've always managed to recover from such situations by using special tools developed just for this purpose. Reading the user manual and taking the necessary precautions do reduce the risk significantly.
Not this time |
I'll be in touch tomorrow |
