| No heat from center vents! | |
Hi all, bit of an annoying problem, i cant seem to get any hot air from the center vents [2006 VOGUE SE] ( surrounding the hazard warning switch]the end of the dash vents [bottom parts ] are blowing out warm air, but , no mater what i do with the thumb wheel for the centers, they stay on cold,would i be right in assuming something has broken here and is it a common fault? and more to the point,how do you fix it? is it easy to get those center vents out because it certainly dosent look it!! thanks in advance of a reply guys !!! KD !! Supercharged 4.2 FFRR in Buckingham Blue,
Gone, Ford Explorer 4.0 V6 petrol,
Gone, Ford Granada Estate Ghia,
Gone, Daimler sovereign 4.0,
Raced, more mk1 & 2 granada's, A60's mk1 cortina's and mk 3 zodiacs than i can remember!
If its too loud then you are too old!!!
